Greeno
Cast Iron
- Jan 23, 2005
- Isle of Man, UK
Hi All,
I had a problem with my HLV-H (UK made) where it was sitting powered up but not actually running when the mains trip popped. Fault finding led to the main fuse in the lathe's L1 input blown. Replacement blew too. This turned out to be an earth fault on the transformer. New transformer wound (three months!)and fitted last week. N.B. Whoever decided to locate the mounting screws behind the windings in the darkest corner of the cabinet deserves Karma in spades.
Now I find everything powers up OK and the motor runs fine in low range but as soon as I engage high the L1 fuse blows again.
Before I head off on a wild goose chase, I'm looking for some advice.
Could this be the result of a cock-up on my part (entirely likely) in wiring up the transformer? I don't see how it could affect the motor, but wise heads might know better.
Can a second insulation breakdown have occurred at the same time in the motor circuit? Seems a bit of a coincidence, but who knows?
How best to troubleshoot this?
Advice is sought!
REgards, Jim
Advice is sought!
REgards, Jim
