I am helping one of the maintenance guys resurect a mid-70's HLV-H which was has been sitting, un-loved, for at least 20 years as I understand.
Something was definately wrong with the vari-speed assy when it was last used (perhaps why it became un-used) as the whole pulley assembly seemed to have walked towards the tailstock, and one end of the shaft had come out of the (headstock side) bearing on the drive support frame.
The parts manual just points to the pulley, and calls it out as "pulley assembly" with no cross-section or other description. I am sure that if I have this right in my mind, the middle part of the pulley should move from side-to-side relative to the (fixed) outer pulley parts - induced by the position of the support frame from the screw-drive...
The middle element on this unit is seized solid, and perhaps explains how when someone tried changing the speed, it walked the whole pulley sideways.
So, am I correct thus far?
If so - what is the procedure to remove the belts and then remove the varidrive pulley? Reading the manual, it looks like I need to move the brake to the side, lift the motor, allowing me the get the belt off the motor - but the actual removal of the belts from the varidrive pulley "assembly" in the support frame is not clear.
Finally - what is the cost for a pair of new belts. The headstock drive belt doesn't look too bad, but the motor drive belt is defiantely past it; but if we are in this deep - may as well replace both....
