pntr815
- Aug 2, 2014
- Philadelphia
Hello all....
Where to begin....So, I'm looking for a Hardinge lathe that is NOT a dedicated second operation turret lathe like a DSM-59 but instead I need one that WILL accept the turret attachment. The reason being is that I need to use one lathe for multiple applications like threading (so I need a lead screw) and I need the cross feed as well. Also, I'd like to set it up with 5C collets (I need a center bore of 1.375). Question 1: Is the standard outside diameter of a 5C collet draw bar? Is it in fact 1.375? Question 2: Assuming the collet draw bar OD is 1.375 does Hardinge make a lathe with that bore diameter through the head stock? Question 3: Are the Hardinge turrets set up for a 9 inch lathe? A 12 inch lathe? Or are they available for pretty much any lathe? Question 4: Typically speaking on a 12 inch lathe are the dimensions across the ways pretty much the same? For instance; would a turret for a 12 inch Hardinge fit across the ways for say, a 12 inch Clausing? Weird questions huh? Thanks for any assistance you can provide.
V.
V.
