I went to look at a split bed DV-59 over the weekend. The cross slide is a model R, the cutoff is a model 7. The spindle taper, both inside and out were a little rough, not gouged, but worn, slight corrosion. I couldn't run it, and so didn't get to hear the bearings. The cross slide is not the original, but is set up for the dovetail bed. The cross slide has 0.006" backlash, the compound backlash is undetectable. No detectable play in the tailstock barrel. One concern was the bed scraping; all surfaces of the bed were covered with small "dimples", say 0.020" by 0.002" deep - is this the original scraping? Also, can that cross slide be adapted to the split bed? There were three or four pulleys from motor to countershaft, also a lever for high/low speed, but I couldn't tell exactly how that lever worked. I posted regarding this lathe on the Yahoo group prior to looking at it and Larry Vanice dated it to late 1941. The seller wants $450; am I walking into a money pit?
Paul
Paul
