Hello!
I am currently going through the machine work program at the local community college. Most of the manual machines we have are pretty hammered. One of the few decent ones left is a Hardinge HLV-H. It's virtually the only lathe I bother using anymore (as both 10EEs are out of commission).
Anyway, today, I was trying to make a couple parts that only had one or two thousandths for tolerance over a length. As the title of this thread explains, I was getting some taper in the cuts. My instructor and I quickly came to the conclusion that it was from the tailstock being misaligned. We quickly disassembled it to find shims between the tailstock and the gib that slides against the bed's dovetail. We put the gib on the surface grinder and smoothed it out (non-sliding side) as to try and remove any high spots. After re-shimming and indicating inside the tailstock quill, it was still a little off. However, tightening the tailstock bed lock was showing us more variation than we were getting while doing the measurments. It made me wonder about the overall accuracy of the system. If tightening the tailstock lock could shift the whole thing over a thousandth or two (or more), how can I be sure everything is lined up when I'm trying to hold tight tolerances? Is it just an inherent part of the design? Does anyone have any advice or experiences with this? To me, it seems like downforce applied to V-ways would be more accurate than a push from one side of a dovetail.
