torinwalker
- Nov 28, 2010
- Oakville, Ontario
Programming Question: G10 P0 Y-n.nnnn not behaving as indicated in Programmer's Manual
Sorry guys, this is kind of a noob question, but in the Hardinge Conquest T42 Programmer's manual under section 16, page 16-19 it shows an example of transferring a part from the sub-spindle to the main spindle.
In this example, it shows setting two work offsets - the first G10 sets the Z axis (which works as expected), and the second G10 sets the sub-spindle work offset. This is so that you can command both axes relative to the zero-offset of the part being produced. Makes sense this way.
Except... the G10 P0 Y-1.75 doesn't seem to have an effect. The sub-spindle moves in absolute coordinates regardless of the work-shift offset I choose.
I tested this using
G10 P0 Z-5.0
G10 P0 Y-5.0
G0 Z0
G0 Y5
and both the turret and the face of the sub-spindle line up at 5" from the main spindle. This /should/ have placed the Y-axis (the sub-spindle) 5" further out than the turret face (that is, 10" from the main spindle nose.)
I even tried combining them into one command - Z works, and Y still doesn't.
Why does the Z work offset function correctly, but not the Y-axis? Can anyone offer a real sub-spindle transfer code example that works?
Torin...
Code:
N84 (TRANSFER TO MAIN) ; Sequence Number and Operator Message
G10 P0 Z-1.75 ; Main Spindle Work Shift
G10 P0 Y-1.75 ; Sub-Spindle Work Shift for Workpiece Transfer
G97 S2500 M14 ; Main Spindle 2500 RPM Reverse
M98 P1 ; Call Safe Start Program O1
M32 ; Sub-Spindle Sync to Main Spindle
M21 ; Main Spindle Collet Open
M36 ; Main Spindle Air Blast ON
G0 Y-1. ; Rapid Part 1" into Main Spindle (Figure 16.16)
<deleted for brevity>
M1 ; Optional Stop
I tested this using
G10 P0 Z-5.0
G10 P0 Y-5.0
G0 Z0
G0 Y5
Torin...
