sam_stlouis
Cast Iron
- Aug 1, 2010
- missouri, USA
I have an hlvh, it has 3 wires on the power cord, each hooked to the 3 poles of the disconnect in the control panel. the second leg has a second wire attached to it that goes to a screw on the panel-that is not shown in the wiring diagram. There does not seem to be a ground wire coming into the machine. Am I overlooking something with the ground, and why is there a wire going from the second leg to a screw on the panel. I found one picture of a machine with a wire on the screw, but cant tell where his wire is coming from.
