alan.bain
- Jul 3, 2008
- Amersham, U.K.
My HLV-H of the metric variety recently had a gearbox problem, where one of the bearing retaining collars on the shaft connecting the leadscrew to the gearbox output shaft came loose and pushed the tumber gear up against the gate peg (breaking it) and jamming the box solid. After dismantling (the manual isn't much help here as it describes the English gear box) and replacement of gate (milled from gauge plate) and a new tumbler gear & various bearings it is now back together and working.
I mounted the new leadscrew thrust bearings on an expanding mandrel and machined matrial off the central ring on one bearing so that when placed back to back with a bolt though centre and held in the outer races there is < 0.5 thou axial play in the central bearing.
However, the drop out at the end of a thread is not consistent. It occurs in one of two places, and measuring some workpieces shows that these are typically 3mm apart which is the pitch of the leadscrew (this may be a coincidence of course). Needless to say this can be a disaster if screw cutting up to a shoulder and the initial drop out is in the far from headstock position as sooner or later it keeps on going and drops out in the near headstock position and hits the shoulder chipping the tool and making a mess.
The gap in the two drop out positions is the same distance whether cutting a 0.5mm pitch thread or a 2.5mm pitch thread.
This all suggests that the single tooth clutch is disengaging at two positions. However, the clutch on dismantling was in perfect condition, was cleaned and reassembled with EP grease as lubricant and to the best of my knowledge there is no adjustment possible for the clutch mechanism.
Does anyone have any ideas?
Alan
Alan
