My HLVH was cutting a .002 tapper with no tapper attachment. After eliminating the Tru Adjust Chuck and Tail stock. I placed a indicator on the Live Center shaft and found .012 of up and down movement. Time to replace the Live Center Bearings
Somewhere on this forum I found a thread on disassembly of a live center. (Cant find in now to use as a link) once the aluminum cover was gently pried off. I found a threaded compression nut that needed a pin wrench to remove. WARNING: DRILL OUT PIN IN HOUSING BEFORE TRYING TO REMOVE COMPRESSION NUT. If you don't -You will gall the threads. It took about 1 hour to repair the threads. In the picture below the pick is at the pin location, Drill it out first. Just FYI and Pictures for reference.
The end bearings 2203H are shot. The center bearing has .125 gap in it. Checking on new bearings locally on Monday.
