G
Guncraft
Guest
Happy Thanksgiving!
I have reassembled the saddle on my mill. I took the two nut system out, cleaned everything, and put it back together. Following the instructions, I adjusted the nuts to eliminate some backlash in the y-axis mechanism. Currently, it is at .003" of backlash for the saddle movement as measured with an indicator. What is the best practice when it comes to adjusting out backlash? Should one leave a bit of backlash to reduced some wear on the nut and screw? Should one always try for zero backlash?
I understand that backlash can be dealt with while using the machine. My question pertains to setting up the machine after having removed and cleaned the parts.
Thank you!
Andy
Thank you!
Andy
