Reading thru Gordon Long's link I gather it may be a little difficult to reassemble correctly. My my RAA is old but appears little used. Gears turn smoothly and quietly, with little backlash. Inspection into the set screw hole I can't see very well but looks like the gears are basically dry. So I'm guessing previous lubrication (liquid) is long since dried up. I have ordered the NLGI #0 grease JRIowa recommended and plan on filling to the set screw level. Any other suggestions? Thank you for info and advise.
