awake
Titanium
- Jan 24, 2006
- Angier, North Carolina
Feel free to skip down to the fourth paragraph below if you want to cut to the chase, but if you want the background, read on: I have just acquired a Bridgeport Series I with the 2J2 head (2hp, vari-speed), vintage 1972. Condition was acceptable - reasonable wear but not much backlash; some rust from sitting unused; the DRO mostly worked (one cable had been pinched and kept one axis from working, but I've already fixed that), and the power X-axis feed mostly worked (a little unreliable at the slowest speeds - I'm hoping that's just a matter of cleaning or replacing the potentiometer).
BUT - because the seller does not yet have 3-phase power, I could not hear the head run before purchasing. (He is a welder, wanting to get into some machine work on the side, and bought a bulk lot of machines from Purolator; this was one of the two mills he bought.) On the plus side, the price was right - $1500, which included delivery and rigging (!!!), and he is a friend of a very good friend, so I felt comfortable moving ahead with it.
I finished putting together an RPC last night and fired up the mill. The head is noisy, rattly, especially at higher speeds - but I was not too surprised, since I understand that this is a common issue with these vari-speed heads. I've put together a 3-minute YouTube video that shows the mill and includes the noisy head if you want to take a look/listen: BP - YouTube
So here are two questions (actually three - 1a, 1b, and 2): 1) I am already searching through old forum threads and YouTube videos and other internet info on what is involved in digging into the head. But a) I'm overwhelmed by the sheer number of posts/videos/etc., so I'm wondering if anyone can point me to the most reliable and/or helpful resources, and b) particularly if you watched the video, it is most likely to be the plastic sheave on the output side, or on the motor side, or is it likely to include a bad bearing, or ??
2) Not mentioned above, but noted in the video, I'm not seeing evidence that the single-shot oiler is succeeding in putting out any oil. Obviously my first step will be to see if the pump itself is working, but I'm guessing the more likely culprit is clogged up lines, or even more likely clogged up metering valves. From the manual I found on line, it looks like the distribution block and metering valves are in the knee. Do I have to take the table off to get to that, or is there another way to access it. (I can't see any other way, but there's always hope ...)
On the plus side, even with the noisy head, and even before I've trammed the head, I tried a couple of test cuts, and I can tell that this is going to be a VAST improvement on my unmentionable previous mill. The spindle seems to be nice and smooth. I do need to make some adjustments on the head controls, but I believe everything works.
No doubt I will have further questions as I put this mill into working order ... thanks for any advice, help, resources, etc.!
