I've recently aquired a BP series 1 with j head and 1hp motor,the vertical gears under the front step pulley (spindle gear?) dont mesh very well, very rounded edges, very rattly when operating. Ive also got hold of another J head 1.5hp so was going to do a straight head swap. However there are some differences and I could use some advice. The new head can be rotated horizontaly but the old one cant, does this matter? I'm assuming I can split it at the mount plate just behind the spindle handle. Does the worm to rotate need to be in a specific position to remove the head? Ive attached pictures(hopefully) of each head.
Thanks, Matt
Thanks, Matt
