So the quill is not horrible and has some light scoring in a few spots that I can feel with my nail. What bothers me is the first 4 inches of downward travel is easy and the last inch is tight. I figured out it has to do with drag from the quill lock. If I hold the lock in full release, the travel resistance over the entire length is the same.
with the quill all the way down, I release the quill lock handle and the handle swings down to the 2 o-clock position. As I raise the quill, the lock handle will drop to the 3 o-clock position after 1 inch of travel and remains at that position for the rest of the travel. Lowering the quill again is fine until I get to the last inch where I need to loosen the quill lock.
Can I swap out a donor quill in better shape or am I looking for trouble with fitting clearances between quill and housing? I will be reusing my spindle which has a TIR of .0004
I have read where people say to never remove quill unless absolutely necessary and yet I see multiple tear down videos with quill removed with no mention of critical tolerances.
Also, Is there a way to have the quill lock handle not drop down under its own gravity?
