Vfd on a Variable speed mill
Results 1 to 9 of 9
    Feb 2018
    Kansas
    Default Vfd on a Variable speed mill
    Can I run a VFD with a 3 phase Alliant knee mill that has a variable speed motor ? Any pros or cons ? Any recommendations on one of I can ? Thanks. This is my first mill so I’m a newwby
    May 2003
    Iowa
    9,827
    3005
    3668
    I do
    Have for years. Actually my second.
    JR
  3. Likes Monarchist liked this post
    Feb 2014
    New Hampshire
    172
    11
    38
    There is nothing that can convince me to not run a VFD on any machine , I use them on everything, total control and phase conversion ... Do it
    Sent from my iPad using Tapatalk
  5. Likes Pathogen liked this post
  6. #4
    Dec 2013
    Fort Wayne, IN
    269
    320
    92
    When you run your VFD on a varispeed head, do you guys control speed via the VFD or the head? Do you guys change out the variable pulley for a stationary one?
    When we fix 2J heads that are run on a VFD, we see that the motor shafts get tore up from being run in the same spot...
    Just a thought.
    Jon
    H&W Machine Repair
  7. Likes JRIowa liked this post
  8. #5
    Nov 2008
    Madera county california usa
    1,984
    16
    449
    We wish we still had the "vari" in ours.
    The previous owner was a small machine shop that stripped out the variable speed parts as they were worn out and replaced with single speed pulley and added vfd, he had 3 phase so matching size.
    We are single phase so it has issues with heavy cuts and back gear is needed.
    The variable speed allows torque to be there if needed.
    Sent from my SAMSUNG-SGH-I337Z using Tapatalk
  9. Likes HWElecRepair liked this post
  10. #6
    Dec 2011
    Maryland
    73
    41
    Quote Originally Posted by HWElecRepair View Post
    When we fix 2J heads that are run on a VFD, we see that the motor shafts get tore up from being run in the same spot...Just a thought. Jon H&W Machine Repair
    When I run my 2J head VFD powered machine, I vary the speed using the mechanical split pulley system. Never have a need to further vary speed with the VFD.
  11. Likes HWElecRepair liked this post
  12. #7
    Nov 2005
    New Hampshire
    366
    365
    217
    I use the VFD primarily for phase conversion, once I used the VFD to slow down the spindle when low is not low enough for some oddball boring job I was doing. Usually the VFD is set at 60HZ and I use the vary speed head. It is quick, easy and works.
  13. Likes HWElecRepair liked this post
  14. #8
    Jul 2009
    Southampton UK
    49
    Default Ditto
    Quote Originally Posted by Warren View Post
    And it means you use still use the varispeed which is meant to be wound up & down thru the range periodically
  15. Likes HWElecRepair liked this post
  16. #9
    May 2003
    Iowa
    9,827
    3005
    3668
    Bill, nothing to add, why?
