Mark Leigh
Stainless
- Jan 8, 2008
- Merced, Calif
Hi all, where can I find a wiring diagram for a Bridgeport built by Textron. On the electrical panel box attatched to the machine the nameplate says Drawing No. WD153D
I am firing up the mill and finding that in high speed the contactor will pop out and stop the motor about 1 minute into running it.
I am confused about the control panel mounted down low, do I have to have the toggle switches in a certain position to run the head or do I just use the hi/low selector switch on the head motor.
I have read that there's protection circuits to stop the head if the x power feed is running and the head stops, or vice versa ??
The machine is a serial number 402730485W Order No 85309 thanks for all replies.
