Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Specific Machine Forums > Bridgeport and Hardinge Mills and Lathes
Bridgeport and Hardinge Mills and Lathes Discuss Bridgeport and Hardinge machines
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 11-20-2009, 01:24 PM
Hot Rolled
Default BP Mill Motor Control Pictures
Here is motor starter I built for my mill's spindle and feed motor. There is also
a on/off switch for the feed motor with a indicator lamp. This reduces the chance
that I might try changing the gears while the feed motor is running. The enclosure
is mounted to the base behind the push button operator station in the first picture.
  #2 (permalink)
Old 11-20-2009, 10:29 PM
Nice work!
What we always use and something to consider in the future are modular terminal blocks like these
Then you don't have to crimp ends on each wire.
  #3 (permalink)
Old 11-20-2009, 11:08 PM
Marcibb's Avatar
Cast Iron
Default Nice
Nice clean wiring job.
Marci
  #4 (permalink)
Old 11-21-2009, 12:04 AM
The real Leigh's Avatar
Very nice work.
One suggestion if I may...
Whenever you use plug-in relays, install the retainer springs. These will keep the relays from falling out when subject to vibration. They should be available for all relay/socket series.
- Leigh
  #5 (permalink)
Old 11-21-2009, 08:02 AM
Stainless
Default Nice!
Nice clean job, Ron! VERY Tidy!
I like putting everything on DIN rails... usually 'cause I get it all in there, and then slap myself for putting everything in the wrong place... then it's fairly easy to move 'em.
  #6 (permalink)
Old 11-21-2009, 02:05 PM
Hot Rolled
I didn't expect so many comments, thank you. Thanks for the suggestions too.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
