Bridgeport way covers & chip guard ideas?
Community On The Web
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    gearhead_bunne is offline Plastic
    Jun 2009
    WI, South Central
    24
    Default Bridgeport way covers & chip guard ideas?
    I have to keep my Bridgeport oiled to prevent rust and the chips really stick to the uncovered Y axis ways. I've searched here and looked at a few pictures of the accordion style and the rubber flap style guards. Since I'm currently unemployed I don't have a lot to spend, but I do have time to build something.
    So lets see your ideas. I know this group is resourceful, someone must have come up with something clever to manage the chips and keep most of them out of the moving bits. Also wondering about methods to keep the little buggers contained to at least one corner of the shop.
    Thanks!
    Paul_C is offline Plastic
    Jan 2010
    Bucks County, PA
    47
    I use a rag as a budget gib cover when needed. A shop I worked at we used a Bridgeport for mostly cast iron. We jury rigged gib covers from thin rubber sheet attached to the felt scraper.
    usmachine is offline Stainless
    Jul 2006
    detroit, mi
    1,450
    +1 to what Paul C says about the thin rubber sheet, put em on fresh ones and take em off old BP's all the time. I use 1/16 thick stuff from a local supplier and it works great
    Prolly about a $10 project and worth many times that
    adama is online now Diamond
    Dec 2004
    uk
    7,923
    Anouther option is to get some of the heavy pvc fabric reinforced cloth - canvas big tar paulins are made from. A strip about 12" wide is folded up concertener style, clamped solid and the edges just warmed with a hot air gun, when released of the clamps once cool it will have formed a clasic bellow shape. I simply caught the edges under the alu way wiper plates. Its amazing how much of the swarft lands on them, perticualy on the non operator side.
    RLamparter is offline Cast Iron
    Oct 2008
    Central PA
    404
    Quote Originally Posted by usmachine View Post
    Where do you buy rubber sheet inexpensively?
    Jul 2006
    detroit, mi
    1,450
    I get mine at a local place called Welton Rubber in Madison Heights, MI. They are a distributor for Gates belts and hoses. Perhaps there is a place like that in your neck of the woods.
    Doug
    karl is offline Aluminum
    Sep 2005
    Fayetteville, close to Pond Bank, Pa.
    121
    Quote Originally Posted by RLamparter View Post
    How about an adult novelty shop ?
    chips&more is offline Aluminum
    Jan 2009
    Calif
    120
    Try Enco (page 871 current internet catalog), they have a nice selection of sizes and types of rubber/vinyl sheeting. And seems fairly priced too! EBay also has rubber sheeting goods. Good Luck.
    Billtodd's Avatar
    Billtodd is offline Stainless
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,426
    Quote Originally Posted by karl View Post
    LOL
    Now I have to clean the coffee of my screen!
    Jun 2009
    WI, South Central
    24
    Well I think I'll avoid the novelty shops....too far of a drive from the middle of nowhere & I'd hate to have to tell someone where they came from in fear of another coffee incident.
    I do have some PVC liner laying around from the recent tile shower remodel. It's not fabric reinforced, but plenty thick enough. I'll try adama's trick with folding & the heat gun and see if I can get anything like the accordion bellows to come out of it.
  11. #11
    Dec 2004
    uk
    7,923
    the trick shouls still work, just remember warm it, till it sofens, not till it melts and becomes a solid!
  12. #12
    neilho is offline Stainless
    Mar 2006
    Vershire, Vermont
    1,023
    Way lube and cutting oil combine with and remove the plasticizers in most plastics and rubbers, leaving the material very stiff after a few years. PVC, neoprene, EPDM don't last well and those are supposedly oil resistant. Buna-N stays the most flexible. It seems expensive, but consider buying the material twice and installing it twice and the initial cost looks reasonable. Available at McMaster Carr.....
    Neil
  13. #13
    Dec 2004
    uk
    7,923
    Neilho lets ee here, 10 minutes work and what $5 in matirials? Say 6 year life span, mine are still going just fine after 5 years. Now how much do you want to spend on just rubber sheet? Heck forget the adult noveltiy store, just cut it out of your special service - very personal, assistants skirt! Heck you can have a lot of funn in any remaining time too!
  14. #14
    SWBrooks is offline Cast Iron
    Jun 2003
    North Carolina
    329
    Default Industrial Roof Membrane
    If you're looking for a good cheap rubber to cover your ways try rubber roof membrane. It is VERY thin and flexible so it is easy to cut, drapes nice and flat over the ways and doesn't get all bunched up behind the saddle and interfere with table movement. If you'll look around for a construction site and talk to the roofing contractor, sometimes they'll let you have the end off of one of the rolls. It might cost you a six-pack but that's still cheap. That's how I got mine and I've yet to see anything that works quite a well. Steve
  15. #15
    the man machine is offline Aluminum
    Feb 2010
    Colorado, USA
    144
    LOL u guys are funny. +1 on the flat material (be it whatever) for the rear section. I have something I use which is made for a mill, sort of a rubberized plastic flat sheet but has ss flat strips as front and rear edge trim riveted on.
    I found it beneficial to drill & tap the front of the ram dovetail 10-32 on each side to secure it and then below that on the column two more 10-32s that hold a bungee cord. This bungee holds the cover tight up against the underside of the ram and against the column, and still allows the guard material to move in and out with the ram.
    I need to start posting pics on here. What I described works extemely well.
  16. #16
    Mar 2006
    Vershire, Vermont
    1,023
    Neilho lets ee here, 10 minutes work and what $5 in matirials? just cut it out of your special service - very personal, assistants skirt!
    Forget the skirt, man! I'm goin' straight for the underwear. Those Depends should work great!
    Neil
  17. #17
    Feb 2010
    Colorado, USA
    144
    Default here:
    Yeah, this is what I described. Keep going the the rubber skirt thing though.
    Post pics if u got 'em.
  18. #18
    swamp man's Avatar
    swamp man is offline Plastic
    Apr 2008
    western washington
    39
    I used toolbox drawer liner from horrible freight held on with metal strips screwed to the column and the saddle Its a little sticky at first but its cheap.
  19. #19
    Chopshopchopper is offline Plastic
    Jul 2009
    Parma, Ohio
    44
    Lightbulb
    JTS Machinery & Supply Co. WebShop Has a set for $39. I can not find it on there web sight but it is in there catalog on page 916. Part # 1-541-400
    I do not have this set but I would like it. I used black cavas from wallmart. I cut it to size and it works great. I needed to soak it with oils after the install though so it would relax. Works great.
    The thing that is nice about the store bought set up is you can blast it with some air to blow the chips off, and it wont flip up and dump all the shavings all over the ways. That is the only draw back to the homemade covers.
  20. #20
    Jun 2009
    WI, South Central
    24
    Crude but effective. These are what I came up with using the .040 thick PVC I had on hand. I used a piece of flat stock and folded it back and forth and used a propane torch to soften / crease the part after each fold. It took a few tries to get the technique down, but after a little practice it went really quick. We'll see how long it lasts, so far so good for my home shop. I'm afraid the really hot chips would melt and stick on so probably not good for a production shop. I have enough of this stuff to last me a lifetime if needed.
