3Likes
Post By wd72588
Post By Shawn Ghormley
Building a RPC for a 1 1/2 HP Series 1
Hi All,
Can I use this motor for a roto phase for the above mill.
1.5 HP motor Hemco Cast Iron 1725rpm 3 phase 145T frame
NEW 1.5 HP motor Hemco Cast Iron 1725rpm 3 phase 145T frame | eBay
My rule of thumb is to have the idler motor at least 30% larger than the motor I need to start. So I would look for a 2HP for this application. Might as well mention a variable speed drive as an option if this is the only machine you want to run. Its easier and more practical. If the VFD is not a viable solution put your feelers out locally. 140 seem like alot of money for a 3ph motor. But then again I live in America's in industrial wasteland and that stuff is all over. Paid 120 for a used 7.5hp, new 10hp, and 2 electrical cabinets.
Thanks WD,
I was looking at the VFD solution it looks like a variable speed thing and not just a phase creator. My mill is a 1985 with a variable speed built in. How would this work? When I looked at the VFD i saw a terminal post that looked like 10-32 screws how would you hook up #12 wire L1 and L2 from my house? Sorry about the questions.
Dan
A variable speed drive with a variable speed mill might be redundant but I am sure you would like the flexibility. As far as wiring a drive, post the model you are looking at and I am sure someone will offer suggestions.
Hello, is this the only pieces of three phase equipment you plan to have? If so a vfd would work, if not I'd go 3-7.5hp on a phase converter.
Thanks Shawn,
Yes this is all I will be running. Should I get a 3hp rated VFD?
I found this-"you cannot use the VFD to power "other" electronics on a machine, only the motor".
I am really glad I joined this forum. The VFD is the best way to go for me, thanks for the direction.
I have one that I am looking at: 3HP 2.2KW 10A 220-250V
VARIABLE FREQUENCY DRIVE INVERTER VFD NEW 3HP 2.2KW i1 | eBay
Will this be okay for one machine 1.5 HP Series 1
What else do you need for controlling or wiring from house panel to knee mill?
Do I have to interface with the RS-485
It will be okay. There is no such thing as free shipping. It is included in the price.
I have seen a similar units go for $65 to $95. Forget about the RS-485 control.
I suspect thse people acquired a bulk shipment of these things. Can you believe
that they don't even try to correct the bad english in the specification.
VFD Single to Three Phase
There are single phase to three phase VFD converters. I bought one for a 3 phase fan. I don't know the cost but it is worth a try.
Jim
Is there a difference between a VFD and a VFD Converter. I am only interested in creating the needed 3rd phase not the ability to vary the frequency.
http://www.phaseconverterinfo.com/ph...verter_vfd.htm
http://www.phaseconverterinfo.com/ph...owerfactor.htm
- You may not post replies
- You may not edit your posts
Forum Rules
