Difference Between Bridgeport Series 1 J Head and Series 1 2J Head Machines
Community On The Web
Results 1 to 4 of 4
Like Tree3Likes
  • 1 Post By averycustom
  • 1 Post By abarnsley
  • 1 Post By JRIowa
Thread: Difference Between Bridgeport Series 1 J Head and Series 1 2J Head Machines
    averycustom is offline Plastic
    Jan 2005
    Lafayette, Indiana
    18
    Default Difference Between Bridgeport Series 1 J Head and Series 1 2J Head Machines
    Fellows,
    After a fair amount of searching I've been unable to ascertain the difference between a series 1 J head and series 1 2J head machine; any insight would be much appreciated.
    Mark
    confederatemule likes this.
    RLamparter is offline Cast Iron
    Oct 2008
    Central PA
    405
    The 1J has step pulleys
    the 2J is variable speed.
    abarnsley is offline Titanium
    Mar 2005
    Palmer, Alaska
    3,060
    I was caught on this long ago.. Lathes.co.uk is not exactly right about this...
    A Series 1 2J IS a 2 hp Vari speed head, says Series I right on label of head.
    A Step pulley J head Mill has a Step pulley Model J head... This is right from old catalogs... NO SERIES marking. NO 1J. Just Model J milling head. There was the Standard 1hp J head and the 1.5 hp high speed J head (went to 5440 rpm) Some catalogs have a generic Series I name for machines, but actual part numbers clearly show just J head or 2J head mills. The column is identical on the more modern machines...
    Series II machines (4J head) are 4 hp and a lot heavier... (Except the for seldom seen Series II Special, which had a Vari speed 2hp 2J Head installed on the larger Series II column)
    Of course nothing to stop someone from putting a 2J Vari speed housing on Step pulley Quill housing ... This would create an older mill (pre series 1) with a 2J Series 1 head.
    JRIowa's Avatar
    JRIowa is offline Diamond
    May 2003
    Marshalltown, Iowa, USA
    8,101
    Quote Originally Posted by abarnsley View Post
    A 2J is the variable speed head. The current model is 2J2 (2hp) the early versions were 2J1 1/2 (1.5 hp motors). Not all 2J heads are marked "Series 1". That moniker didn't come out until the Series II was released in 1971, which had a 4J head on it unless you had a Series II special which had a 2J head.
    There really is no "1J" its just a "J" head. One letter like the M, C, R, and T heads.
    Abarnsley is correct about Tony's site. A J head was never a Series I.
    JR
