Installing A Sino DRO on a Bridgeport
Community On The Web
Results 1 to 12 of 12
    bradjacob's Avatar
    bradjacob is offline Stainless
    Nov 2008
    Easton, PA
    1,849
    Default Installing A Sino DRO on a Bridgeport
    Does anyone have any pictures of your installation or how you mounted the scales, etc?
    sophijo is offline Aluminum
    Oct 2010
    SE Michigan
    182
    Brad,
    Did you ever get any pics? I have some from a recent install if you want them.
    Dave
    bradjacob's Avatar
    Nov 2008
    Easton, PA
    1,849
    Quote Originally Posted by sophijo View Post
    Brad,
    Dave
    Sure Dave, I'll take em. PM me and I'll give you my email, or I think you can through the forum.
    sd624's Avatar
    sd624 is offline Plastic
    Nov 2012
    Michigan
    35
    Here some of the one I just did.
    I used a spacer block to adapt to the mounting holes that were already in my knee and then another one for the saddle.
    sd624's Avatar
    Nov 2012
    Michigan
    35
    The X axis was the easier of the two. Just center it on the table mark, drill, and tap 4 holes. Since I used both mounting brackets on the Y axis I did have to make a bracket though.
    sd624's Avatar
    Nov 2012
    Michigan
    35
    The bracket to hold the display is designed to go over the rear bolt for the head tilt on the ram. Doesn't make since to me since you would have to remove the arm anytime you need to adjust the head. So I mounted it just above it.
    hope this helps.
    bradjacob's Avatar
    Nov 2008
    Easton, PA
    1,849
    Dave (and to my other friend Dean) - guys, thank you SO much. The pictures and video were EXACTLY EXACTLY EXACTLY what I wanted. With one look at these photos and video, I know what to with zero questions.
    *doing the happy dance*
    bradjacob's Avatar
    Nov 2008
    Easton, PA
    1,849
    I got one scale mounted perfectly. Really quick, does anyone know how to eliminate the VERY LAST digit and make second to last only read in halves?
    bradjacob's Avatar
    Nov 2008
    Easton, PA
    1,849
    Quote Originally Posted by bradjacob View Post
    Edit - I got the DRO to have only 4 decimals.
    My question is - does anyone know how to make the LAST DIGIT read ONLY in either 5 and 0 ??
    jh628 is offline Plastic
    Sep 2012
    Utah, USA
    10
    It sounds like you got the installation figured out, but I will throw in a couple pictures of the brackets I made for my installation. The X-axis was too simple to justify a photo, but here are the Y and Z-axis mounts:
  11. #11
    bradjacob's Avatar
    Nov 2008
    Easton, PA
    1,849
    Quote Originally Posted by jh628 View Post
    Yeah, those are Sexy! Nice, clean installation. I'm going to be getting a bar to mount to my Y holes (alady there from bridgeport?). Then attach the scale to it, etc...
    I'll be posting sme pics just as soon as I'm 100% done.
  12. #12
    Winmac is offline Aluminum
    Dec 2011
    Cape Breton, Canada
    169
    I doubt its possible, like other folks with the sino who find the 4 th decmal annoying i put black electric tape over it.
