Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By zwitter
Thread: Konia Powermill FV-1
    GordoB is offline Plastic
    May 2011
    Sydney, Australia
    26
    Default Konia Powermill FV-1
    Hello Machinists.
    Seeing as this is my second post, i feel as if i am at the pinnacle of noobs on this forum.
    Long story short, and getting to the point. I have found an old Konia powermill sitting in the corner of my local technical college (Sydney, Australia) From what i can deduct, it has DRO on X and Y axis, and Powerfeed on the X and Z axis. On the Ram, there is also a Slotting head (brand/model i am unsure about) which is mounted on the rear end of the machine. It looks like the whole ram assembly could pivot around the central pedestool (there is probably a more accurate name for this) to enable the use of the slotter.
    Essentially what i am looking for is a Manual on the Milling machine itself and any other relevant information on the machine (if possible)
    Any help would be appreciated
    GordoB
    JRIowa's Avatar
    JRIowa is online now Diamond
    May 2003
    Marshalltown, Iowa, USA
    5,690
    Gordo,
    First of all, it's Kondia
    IIRC, the FV-1 was either a 2 or 3 axis CNC machine. If it's manual, somebody has converted it. The 2 axis machines were Dyna-path and the 3 axis were Hurco.
    Here's the Kondia website, they can probably help with a manual if you have the serial number and the machine has not be converted.
    KONDIA - Atencin al cliente
    JR
    May 2011
    Sydney, Australia
    26
    Thanks JR,
    I think i realised i had made the mistake of calling it a Konia instead of a Kondia about 5 minutes before i went to sleep last night.
    With this Kondia im looking at, it has the manual feed handles on the end of the table with the powerfeed on the x-axis only. I am highly doubtful that it has been modified seeing as it is a Government run institution (who have a reputation of leaving things the way they are).
    I have just sent off an enquiry to Kondia about this Mill so fingers crossed
    Thanks for the input
    May 2011
    Sydney, Australia
    26
    You wouldnt happen to know what the Taper is on the Arbors by any chance would you??
    JRIowa's Avatar
    May 2003
    5,690
    By arbors, do you mean what the spindle taper is?
    IIRC, available either in R-8 or ISO-30.
    JR
    May 2011
    Sydney, Australia
    26
    JR,
    your Just Full of good knowledge. Just answered my next question about the mill.
    im pretty sure its an ISO 30, based on looking at the way the flange lines up on the mill. i didnt find a keyway in the spindle either, so it seems to be leaning towards the ISO 30.
    While im on the ISO 30, how does it differ from the NMTB 30 taper if at all?
    Thanks again
    JRIowa's Avatar
    May 2003
    5,690
    The taper is the same, it's the flange and the retention areas that are different.
    An ISO holder is basically a CAT holder with additional provisions for coolant. Many European machines induce coolant through the tool holder flange instead of through a hollow retention knob as the CAT holders. You "should" be able to use an ISO holder in a CAT machine, but not necesarilly vice-versa.
    A NMTB holder has a "knob" on the small end of the taper and a slightly different sized drive key. With a little modification, you should be able to use an ISO holder in a NMTB machine.
    JR
    electrosteam is offline Plastic
    Apr 2009
    Australia Sydney
    5
    GordoB,
    I have a FV1 with 3-axis CNC in Western Sydney.
    My machine was amateur converted with Linux and EMC2.
    It is in pieces mid-clean/review/overhaul but it was working fine when I got it.
    The previous owner was doing impressive special components for motor-cycles.
    I have sent you a PM.
    John.
    May 2011
    Sydney, Australia
    26
    Hi John,
    Its good to know that there are a Few of these Kondia's Hanging around the City. I havnt picked mine up yet, still finalising the sale of it.
    My Kondia is a Completely Manual machine. it has the powerfeed and DRO on it currently but that is just about all, a CNC retrofit is on the cards in the future for mine and i am hoping to go down the EMC2 pathway (my IT background has brought me up to basically live linux for computing).
    I will be sure to keep you in mind if i have any questions about the Mills.
    Gordo
    stejac is offline Plastic
    Jan 2011
    Melbourne Australia
    Good day fellas,
    I am looking to purchase a Kondia FV1 Powermill ... I have been offered a very well looked after (in excellent condition) step pulley version which I am very keen to get ... BUT ... I have been hard pressed to find any information on where to get parts either here in Australia or from the USA if and when it becomes necessary.
    I intend to run it with a VFD to allow operation from a single phase 220v supply.
    Has anyone out there got some info that will help ???
    Thanks Steve
  11. #11
    zwitter is online now Plastic
    Jun 2011
    Sydney, Australia
    Default I too have a Kondia FV-1 Powermill
    Hi All
    Just about 3 weeks ago i bought a Kondia Powermill FV-1. It was listed on Ebay a few times then on graysonline. I was encouraged by the seller to buy it and now have it in the garage in 2 bits. head on a pallet and the base. I got a horizontal milling attachment and odd bits but no actual milling cutters etc. It is in good condition, although the connection for the power to the head has corroded solid and the rubber backing perished. it has ISO30/NT30 spindle taper.
    Despite what was said above they were sold as manual versions right from the start. Mine has no DRO and only the longitudinal feed. there is a lubrication pump in the bottom of the main housing.
    You are correct in saying there is nothing on the web about kondias! I searche and searched. Apparently there was a dealer here until a few years ago but no longer.
    I do have the manual for the variable speed head and the FV-1 powermill.
    I would be interested in knowing any one else who has one and maybe comparing and pooling some information.
    My background is electronis not metalwork. This is a hobby!
    james
    Rydalmere, Sydney, NSW, Australia
    stejac likes this.
  12. #12
    Jun 2011
    Sydney, Australia
    Default Put the head back on the Kondia FV-1 tonight!
    I transported the mill home on a car trailer in 2 bits. The base and the ram with the head attached. Tonight I rigged up the hoist and stood the ram up on the pallet and then a complex webbing arrangement to lift up flat and not twist due to the top heavy centre of gravity. got it up and in place in 30 min or so then well over an hour to get the "spider" and bolts back in though the hole in the side of the base!
    Much happier to have it back together as there was a risk of damage lying on the pallet!.
    The plug for the head was stuck in the socket so tomorrow night I plan to replace with a new one from RS.
    Guess I will need some tooling and a vice soon!
    Cheers
    james
  13. #13
    May 2011
    Sydney, Australia
    26
    Good to see you got it home in one piece.
    Im still working through the formalities in the sale of my Kondia -- you know what the state government is like haha.
    I have decided that im not going to risk damaging my Kondia when i move it, im pretty sure it weighs around the order of 3.5 - 4 tons and the thought of moving it myself is a little intimidating. Theres a rigging / heavy transport company based locally that i have ties to so i shall be asking them when the time comes to move the Mill. I dont have any ideas as to the eventuality of the slotting head on the other end of the ram, but only time will tell.
    Alll the best with getting your Mill to operational workings.
    Gordon
  14. #14
    Jan 2011
    Melbourne Australia
    Hi Guys,
    I'm still debating as to whether to buy the Kondia offered to me ... looks like a very well put together bit of kit though!
    I have been in contact with the US agents Clausing ...
    Clausing Service Center
    They tell me that they still support the machines BUT that due to the age of them SOME parts may become difficult to acquire .... though they did not go so far as to tell which parts they may be ??
    The story continues ...
  15. #15
    Mayhem's Avatar
    Mayhem is offline Aluminum
    Nov 2010
    Perth, WA, Australia
    73
    Hi guys,
    I'm on the other side of the country from you and have just picked up a FV-1. It needs some work, so I have been searching for some info to assist me with this.
    I did manage to find a free manual on a French site but so far, there are some discrepancies between the manual and what I see on the machine. Perhaps it is the Spanish --> French --> English translation!
    The serial number is E-37 and the head states it is one of the Spanish made machines. I believe that Clausing purchased Kondia, but I am unsure if the Clausing Kondia mills were still made in Spain or not. I have sent an email to both the Spanish and US sites listed above and will wait for a response.
    I'm curious as to whether any of you unearthed any further information or resources?
  16. #16
    Jun 2011
    Sydney, Australia
    Default Hey guys i have the manuals!
    Hi guys I have the manuals and getting the mill up to scratch to use it. I am interested in where and how your DRO is attached as i expect my 4 axis DRO to arrive next week.
    Would swap manual for some photos and info ?
    Cheers
    James
    Quote Originally Posted by Mayhem View Post
    Hi guys,
  17. #17
    Jan 2011
    Melbourne Australia
    G'day Gents ...
    I finally bought my Kondia FV1 Mill.
    As per usual it arrived at my home just as I was about to depart for a 3 months away work tour .... so I will not get to play with it until September sometime.
    A quick inspection has made me very happy with the purchase it appears to have had a very easy life to date and is in VERY GOOD condition.
    I went with the 'pay a bit more and get a good machine option' and that would appear so far to have been a good choice ....
    The machine is a fully manual step pulley 2hp R8 spindle and was made (or so I was told) in 1984. It also has a Newell DRO on the X & Y axis.
    I have a Mitsubishi 720 series single to 3 phase inverter drive ready to set up for it ... just need to get back home and sort it all out !!!
    I can hardly wait ...
