Results 1 to 4 of 4
    jrlandau is offline Aluminum
    Jan 2003
    San Jose CA USA
    101
    Default Limit switch help on a BP retrofit
    I'm doing a retrofit on a BP Series 1 CNC, and need help with the Z axis limit switches. I'm planning to use Mach 3 on a PC.
    The BP originally had 3 limit switches on the Z axis, top and bottom as usual, but the third one is a "deceleration switch". It is used to slow the travel before hitting the top limit, apparently if it's going too fast something bad happens.
    Can anyone suggest how to utilize this switch, or handle the function some other way?
    smdubovsky is offline Hot Rolled
    Apr 2008
    MD
    621
    Typ use as home. Then the other two can be wired as hard limits to the drives.
    Mark McGrath is online now Titanium
    Mar 2002
    Scotland
    3,948
    Quote Originally Posted by jrlandau View Post
    The outside pair are hard limits.
    The inside one is used when referencing the machine and tells the control to look for the index pulse from the encoder.
    legendboy is offline Aluminum
    Jan 2008
    Canada
    225
    I used that switch for home. The other 2 are estop as mentioned
