Lubriplate 107
Community On The Web
Results 1 to 4 of 4
Thread: Lubriplate 107
    JRIowa's Avatar
    JRIowa is offline Diamond
    May 2003
    Marshalltown, Iowa, USA
    8,068
    I just recieved this from Lubriplate:
    We do still manufacture the Lubriplate No. 107, however the product we recommend for Bridgeport machines is the Lubriplate No. 105. The Lubriplate B-105 (B standing for Bridgeport) is a 1 .75 oz. tube that screws right into the machine.
    Sincerely,
    Dan Moroses
    Lubriplate Division
    Fiske Brothers Refining Co.
    jlrsn is offline Aluminum
    Jul 2002
    8,000' up in the Rocky Mtns of N Cntrl NM
    59
    I just looked at the Lubrication Plate on my Bridgeport 2J2 and the recommended recommended lube for the Vari-Drive is Lubriplate No. 107. After I compare the specs I'll probably start using Lubriplate No. 105.
    Thanks for the info!
    Jim Larsen
    Hayward, CA
    daylate Guest
    Where does it screw onto the mill? What does it lube?
    Jul 2002
    59
    On the Bridgeport 2J2 Variable Speed Head it lubricates the Vari-Drive. On my 2J2 it states to remove the 5/16-24 Set Screw "A" located on the left side of the Vari-Drive and screw in the tube of Lubriplate #107 (now #105?). Then you squeeze in approx 1/2 teaspoon of the Lubriplate. Your supposed to do that every 6 months. You should also work the HI-LOW Lever while greasing the Vari-Drive.
    Jim Larsen
    Hayward, CA
