Results 1 to 4 of 4
    lowCountryCamo's Avatar
    lowCountryCamo is online now Cast Iron
    Jan 2012
    Savannah, Georgia, USA
    318
    Default Running in back gears on BP is loud. Normal?
    Running my Bport in back gears is quite loud. Is that normal or something I should look into. No crunchy noises, just sounds like a bunch of gears winding out. Much louder than running gears on my lathe. Thanks.
    DMF_TomB is offline Stainless
    Dec 2008
    NY, USA
    1,135
    Default BP noise
    Quote Originally Posted by lowCountryCamo View Post
    Yes the lower the speed the louder it is. You need to compare with other Bridgeports to get a fair comparison. This is also why even if a mill has a 1.5 hp to 3 hp motor you get closer to 1-2 at the cutter as the drive efficiency goes down at lower speeds.
    Winmac is offline Aluminum
    Dec 2011
    Cape Breton, Canada
    130
    I would not consider this normal, by this description its possible that the highrange drive is partially engaged while running in back gear.
    jhruska's Avatar
    jhruska is offline Hot Rolled
    Jul 2009
    Munster, In. USA
    780
    If the splined shaft is out of 'time' with the detent then the bull gear may be forced up into the cover plate.
    Varispeed or step pully mill?
