Results 1 to 15 of 15
Like Tree6Likes
  • 1 Post By fpworks
  • 1 Post By litlerob
  • 3 Post By fpworks
  • 1 Post By WILLEO6709
Thread: 8 axis lathe
    precismeca is offline Plastic
    Jun 2012
    wallaceburg ont. canada
    Default 8 axis lathe
    Any suggestions on which software to use for an 8 axis lathe. I am currently using mastercam V7.2 (lol). It works for what we have. Esprit, edge cam and an updated version of master cam have been suggested. Any info will help.
    cadcamwiz is offline Cast Iron
    Dec 2011
    Tennessee, Philippines, SoCal
    276
    Partmaker would be ideal but also big money.
    litlerob's Avatar
    litlerob is offline Hot Rolled
    Jun 2009
    PDX, OR
    542
    When you say "8 axis" do you mean; X,Z,Y,C and a Sub Spindle?
    fpworks is offline Hot Rolled
    Nov 2006
    FL
    869
    Gotta have two turrets for 8 axes.
    Having said that, Partmaker or Esprit are the only ones to consider if you plan really getting the most out of that machine.
    We use Edgecam for our six axis (one turret) ...it would work for a second turret, but it doesn't have multichannel infrastructure, so you would have to copy and paste code together if you want to do more than one thing at a time.
    jdj likes this.
    dstryr is offline Stainless
    Jan 2010
    Gilroy CA
    1,110
    NX can handle this.
    litlerob's Avatar
    Jun 2009
    PDX, OR
    542
    Some people refer to an 8 axis lathe as all 4 axes (single turret) work on the main and sub, some people refer to 8 axis as a machine with 2 turrets, some people refer to their Swiss' as 12 axis because they have 3 turrets and 3 spindles, having more turrets doesn't change the axis motion it only changes how many ballscrews the machine has. That said, as fpworks has 6 axes, that means he has an A and B axis in addition to X,Y,Z and C, is that correct?
    Robert
    Nov 2006
    FL
    869
    Quote Originally Posted by litlerob View Post
    ?.. That said, as fpworks has 6 axes, that means he has an A and B axis in addition to X,Y,Z and C, is that correct?
    Robert
    X,Y,Z on turret (that can be used on main or subspindle)
    C on main spindle
    C on subspindle
    W (or B) on subspindle position (for pulling or transfer)
    =6 independently controlled axes
    Mar 2011
    MASS
    155
    dare i say mastercam!! hahahahahah
    Dan-
    litlerob's Avatar
    Jun 2009
    PDX, OR
    542
    Quote Originally Posted by fpworks View Post
    C on main spindle
    C on subspindle
    You haven't added any axes geometrically, except B for the sub which really doesn't make sense, because a B-axis is one that rotates along the Y axis of a graph. I have run loads of these machines, I just don't think they deserve all those axis designations, mathematically. Reverse motion on the z axis does not denote a new axis----
    W (or B spindle)
    Robert my ±2
    cadcamwiz likes this.
    Nov 2006
    FL
    869
    Robert my ±2
    Subspindle motion is called "W" all over the machine, but you can't program the subspindle position with W because that is incremental Z. (so somebody at Mazak decided to use address B...which is agree is strange) Subspindle motion/position is not "reverse Z" since is accomplishes something that Z cannot do...which is translate the part with respect to Z. I think that is enough to deserve it's own independent axis (after all, it does have it's own ballscrew, servo, drive, etc.)
    Ox, Joe788 and Dan B like this.
  11. #11
    jvangelder is online now Aluminum
    Aug 2010
    Southern NH, USA
    176
    Gibbs will run a twin turrett as far as i know, with a sub aswell
    And our hyundia-kia C axis lathe denotes the subspindle motion with a B aswell, didnt make a bit of sense to me either.
    -Jacob
  12. #12
    aldepoalo's Avatar
    aldepoalo is offline Cast Iron
    Mar 2011
    Clearwater FLA
    433
  13. #13
    jdj
    jdj is offline Diamond
    Oct 2007
    detroit,mich.
    4,449
    That would have been my guess!
    Two INDEPENDENT turrets/slides. I run some with 2 turrets, but the are on the same slide.
  14. #14
    SeymourDumore is offline Diamond
    Aug 2005
    CT
    5,432
    Robert my ±2
    Robert
    Not on a lathe. B axis is not a rotating axis, it is usually a the subspindle. Just like the Mazak, Mori uses it for the same purpose.
    I would actually call it a sub Z-axis as it really relates to Z axis motion.
    On a Mori NL, the X, Y, Z and C axis are the same axis, only the Z direction varies depending on which spindle you use.
    With the addition of the B axis ( subspindle motion ) that, in and of itself would only translate to a 5 axis machine.
    The only reason I would classify it as a 6 axis is because you can synchronize the sub with the main.
    IOW in reality you have a C1 and C2 axis, where C1 is the main spindle and C2 is the sub.
  15. #15
    WILLEO6709's Avatar
    WILLEO6709 is online now Diamond
    Nov 2001
    WAPELLO, IA USA
    4,107
    Lathe parts are geneerally relatively simple,,,and those live tools generally are not doing massive 3dcontouring programs, so why not code it by hand? You'd be amazed at some of the stuff hand coded.
    jdj likes this.
