I ran into a problem last week with HSMWorks on a HAAS VF3 Mill. I was milling a circle that was 8.17" in diameter with a bore of about 3".
The OD was cut in a football shape with the x axis dimension being 8.17 and the y axis dimension being 8.135". So there is about .035" difference in the 2 directions.
I determined in the cimco back plot window that the arc center was being calculated off center by.0173" and .0007 the axis. The tool path was split into 2 arcs on being .0173 above center and one being .0173" below center.
This is the second time I have had HSMWorks code scrap parts for what should have been a simple circle. I thought it was fixed after the first time and to be fair this is a different error I guess, but still revolves around the same kind of issue.
I used the "R" word for the arcs, HSMWorks IMO is passing a wrong start point to the arc and when the arc center is calculated it is off by a magnified amount. I am being told it is a control issue since the CNC control can't compensate for the bad start point. Sounds like bull to me. How could a control compensate for a bad start point from the software.
I have never had any issues with using the R word in other software. I also realize thru this that any error in start position could be easily magnified in the error the arc center is off. I will be using IJK from now on as the problem does not seem to occur with that code since the center is explicitly defined and can handle a little bit of start point error.
Here is a link to the discussion.
Solved: Re: Arc center is not correct - Page 3 - Autodesk Community
Has anyone seen these kind of errors in generated code before using R word for arcs? I mean this was a real eye opener for me that a start point being off .001" could throw the center off .0173?
Here is an example of some of the code I am getting. This error is only about .014 vs the .017 but still pretty bad. Arc center should be 0,0 for the G2 arcs and a 8.17" diameter with a .5" endmill
Code:
G3 X4.3313 Y-0.1785 R0.0164
G2 X-4.3313 Y0.1785 R4.335 F60.
X4.3313 Y-0.1785 R4.335
G3 X4.3792 Y-0.2305 R0.05 F30.
