You probably don't need to draw sketches.
Is this Inventor HSM Express or the full blown deal? 3D Adaptive will be a much nicer toolpath as it's model-aware and you can use Rest Machining options that look at the previous toolpaths. The 2D features are not, and most of the time you can define areas using part geometry. Every once in a while you do have to draw a sketch, but after using HSMXpress (in SW) for the last year before we just picked up HSMWorks I got pretty good at avoiding extraneous sketches.
Edit: BMX, downhill or freeride?
Edit 2: I can see this is 3D Adaptive Clearing so definitely the full version. Can you make a screencast of your simulation, or take some shots of your geometry selection tab and model? I also highly recommend the Autodesk CAM forum here:
https://camforum.autodesk.com/
