viper
Titanium
- May 18, 2007
- nowhereville
Basically I have a part that is about 1.5in Dia with 6, .160" dia pins sticking up so I need to machine around everything to leave just the pins sticking up. radius for the circle of 6 pins is .5in and I am wanting to run about all the pins with a .375 cutter. I want to cut full depth (.250") by leading into one side and stay in the part running around these pins until done, then lead out.
I have tried about everything in MC from contour paths to surface paths, nothing seems to get even close and I cannot keep the tool down or just cannot generate the paths at all. I am not sure if there is a surfacing path that would be best for this or if I am on the right track with contours. I am getting a bunch of retracts to go to the next pin, and plunges in the wrong spot which I cannot alter. Any ideas would be appreciated. I do not have too many obstacles on the part other than the pins. I do want to use Ccomp so running in the same rotation would probably be best.
