KilrB
Stainless
- Feb 18, 2007
- Angleton, Texas
I need some help gentlemen.
We have an opportunity for some much needed work cutting flooring and signs on our waterjets.
But ...
We are having problems getting usable profiles to program from.
The customer is sending us .pdf files of artwork and text.
We currently have a guy who opens these in Adobe Illustrator and saves them off as .dxf files for us.
He has (AFAIK) used every available option but they are still a mess.
Whether we import them into Solidworks or straight into Mastercam we have broken profiles, multiple overlaying entities, or at best complex splines.
Best case scenario is with the splines ...
Two of our waterjets will cut splines, but the splines so complex it takes them much longer than it should with the constant acceleration/deceleration on thousands (or tens of thousands) of entities.
Our third jet will not import a spline so we have to explode it to machine it and, again there is the acc/dec problem on so many entities.
Simplifying the profiles manually in Mastercam on the other hand is very time consuming.
If we can't make this easier and speed up the programming and cutting times this work will go elsewhere ... and we really need this work now.
So ...
(Assuming you cannot get a .dwg/.dxf from the customer)
What are the rest of you using/doing to make this process easier and faster?
But ...
So ...
