Richard/SIA
Cast Iron
- May 13, 2007
- No. Nevada
Seems my issue with the Fanuc 3000C control may be the PC used for DNC via printer port?
I did find one machine parameter that had to be reset after the recent move.
Situation is that the machine seems fine, all the axis move, "Home" works, but the program does not run.
Send the BTR file and press cycle start.
Cycle start lights but the machine makes no moves.
The machine is aware of the program, it locks out manual mode control.
The DNC just scrolls through the program over and over.
I put a RS-232 check tester in line.
I notice that two of the LED's are not lighting but am unsure if they should.
The two that remain dark are 11 and QM.
I've been having start-up issues with that PC as well.
My newer PC does not have a 25 pin serial printer port.
I've been told conflicting information regards the utility of USB to Serial adapters.
Some say they work great, others that do not work at all.
If the PC/serial port IS the issue I may be able to add a card to my newer PC?
Since feeBay cannot move this machine out for me via a sale I suppose I'm up for repairing it again.
At least until I can find a newer machine that is not so far away that shipping exceeds the machine price.
PC parts should be relatively cheap.
