Hi,
Some may have seen my other thread where I'm finding my low level 3D CAM software wasn't cutting it when it came to having vertical walls (slots), as some would consider 2.5D features mixed with 3D contours. The fixed stepovers could not create accurate parts where I needed close tolerance (vertical walls) without creating such a small stepover it wasted a ton of time, where a smarter CAM package presumably could detect the walls and finish them at the right distance.
I reached out to some shops looking for unused software and have the possibility to buy an old PowerMill seat if I can confirm I can buy it resale... I've seen some packages, and this may be one of them, where you aren't allowed to sell the dongle. I don't see why it would be a problem and they didn't bring it up but I want to double check. It is a 2010 version that has been dormant since the guy that ran it left but I presumed it had more than enough features I need at this point. I did some online training and exercises via some PDFs I found and everything seemed pretty straight forward up until I got to put my hands on it with a sample part. When I went down to make sure it was running and try it before I committed to it and I could not solve my original issue:
Quickly creating a tool path for a 3D/2.5D hybrid part and have a finishing path that automatically finishes the walls and flats (horizontal planes) to the exact spec.
I played with the roughing (3D clearance) strategies a bit, and that seems plenty fine. But I spent most of the time trying all of the Finishing strategies and all the various options for them and could not seem to get an acceptable result. I'm sure this is due to my ignorance of the software because it seems quite robust.
Can someone give any tips on how to approach a part a like this? I have lot of these types of parts and shaving the cycle times down to last second is not important for me... but being able to open a part like this and have it ready for post in 15 minutes is.
The way I was trying to set it up in PM was a 7/16" Flat rougher roughing pass, 1/4" flat rest roughing pass, 1/4" ball finishing pass, 3/16" flat finishing pass (the slot on top is only .210" wide). Might not be the most ideal, but it was working well for me on my old software outside all the wasted moves due to the static stepovers. The other thing was I could not figure out how to do on PM is Rest finishing so the 3/16" would hit only the spots the 1/4" couldn't reach instead of redoing the whole part. On this part the only areas that are critical are the right angles/flats.
Is it standard procedure to use 3D Area Clearance as a finishing strategy to obtain the Rest strategies? The only reason I didn't consider doing that is the training suggested 3D Area Clearance is roughing only.
