Olokio
- Apr 9, 2014
- United States
I have searched all over and I can not find a thread for this so here it goes:
I am trying to form threads in a 3d model in Bobcadcam V28. I have a model, roughly a 2 5/8 id tube that I want to display 2 5/8-12 threads in for display purposes.
Specifics: thread major @ 2.535in, thread minor @ 2.625in, thread pitch @ 0.0833, thread depth @ 1.0in
What I have tried: I used the spiral command to wrap a spiral at the thread major inside my tube, then drew the geometry for the thread pitch minor - major with a 60 degree cut out and tried to sweep the angle along the spiral path. I get a rendering for the sweep but the angle seems to rotate around the spiral changing the orientation to the top where the triangle is backwards. I was going to try and boolean subtract this rendering from my tube model to cut out the threads but it is not right.
I hope this makes sense to someone and any help that could be shed on the issue would be appreciated I can try and upload pictures of what I am getting but I am looking to see if anyone else has successfully modeled threads in bobcadcam v28, how did you do it?
-Chris
-Chris
