Deyeno
- Aug 21, 2012
- Singapore / New Zealand
Hi All,
I have been approached to help develop a product, for which there is a market, and also source a suitable Mill and Lathe, part of which is also looking for a CAD / CAM package which is suitable for a Brother M140X1 Machining Center(Dealer has 3 units arriving in 3 months), the lathe will mostly like be a QTP 50s or QTP 100S(Dealer has both machines in stock).
The machining is not complicated, relatively straight forward, but need to do operations on all 6 faces of the blocks, similiar to the attached drawing. The raw material dimensions will be 180mm x 80mm x 22mm.
Materials being machined will be Aluminum split between (Grade 6061-T6), Stainless Steel (Grade 410) and if the need arises 2 to 4 pieces of Titanium (Grade 5(Ti 6Al/4V).
So I would like to hear from Owners / Programmers / End Users , whom run this machine, regarding the Pros / Cons of the software they are using.
Brother here are recommending MasterCam, but what I have been reading here on the forum, seems there are problems, but as always that can be subjective as people always have their own preference.
Thanks ...
Kevin
Thanks ...
Kevin
