greenbuggy
Stainless
- Oct 6, 2005
- Firestone, CO
Looking for advice on what's out there for generating trochoidal toolpaths.
I've got a product line I've been making out of RR steel. This railroad track steel, it's nasty stuff, worse than the worst stainless I've ever had the misfortune of dealing with. Something like 1080 but with high enough manganese content that it work hardens if you look at it cross eyed.
I had a guy who had a mastercam seat and was working with me to generate code. He was using a Mazak post processor and other than needing to void out a couple lines at the beginning of the program (caused error on LinuxCNC - voided out and it ran fine) this was working well. Unfortunately he's been very busy or sick or something and what was initially working well is not happening on a timeframe that I'm comfortable with anymore. So I'm thinking I need to bring this in house if its affordable or find a new guy that can do odd programming jobs for a few bucks.
I don't know that you would exactly call this HSM...my machines are old and slow and I don't have the cash for a nice shiny new VMC. My Lagun retrofit knee mill tops out around 3300 RPM and 225 IPM in X/Y. I'm running ~2200 RPM on a 3/8" 4 flute solid carbide ALTiN coated fine roughing end mill with 2 air blast nozzles making 1/2" DOC roughing cuts. Flood coolant not exactly an option on this machine.
I bought an older Okuma VMC with a Fanuc 6M and the option for flood coolant, but it won't be up and running for at least a month or two. I have some operations I'd like to get done before that happens.
So, I know there's some add-ons for LinuxCNC and various G-code generating wizards in python and online, but so far nothing much I can find that actually do trochoidal paths. I'm wondering if there's anything at lower cost than a mastercam/SolidCAM seat that can create these same sorts of toolpaths, or if I'm stuck paying someone else to create code for me til I have enough cubic dollars to buy the software I need.
Most of this is roughing, so the paths themselves are pretty straighforward point-to-point type work. No real 3D modeling or CAD work necessary. I also have a pretty simple drilling operation I'd like to do with a 3/8" end mill if thats possible, need to get a 1.12" diameter hole 1.5" deep but using the same sort of technique.
