| CAD / CAM Computer aided design/ manufacturing software issues |
01-17-2008, 04:33 PM
CAD Software Recommendation?
Hello. Any advice on a simple free or low cost 2-D CAD software for hobby use? Any CAM properties are completely un-necessary. It would be for the design of bagpipe chanter bores. Because much of the chanter bore data available is in the form of measurements taken with soft probes, NURBS splining ability would be desirable to connect the measured points. Being able to toss in a revolved surface would be nice too. Other than that, just basic CAD drawing functions are all that's needed. It should be relatively easy to learn also, as I'm posting this question for other hobbyists who are not necessarily machinists. Thanks in advance for any help. - John
01-17-2008, 06:06 PM
Hot Rolled
I used to use autocad years ago (version 7 to get an idea how long ago). When I got back into this and needed a cad program I tried a couple. Alibre was powerful but the documentation was week and the program had enough bugs to be painful. Bobcad was just painful - I hear that the new version is getting better but I am not going back there again. For the basic cad things that I do (adapter plates, fixtures, 2.5d drawing) I have found that Viacad does a good job ( www.punchcad.com/products/viacad2d3d.htm ). They have a version for both Mac and Windows, and both work well. Documentation is good and there are a lot of tutorials built in. For $99 and a free demo, it is worth it.
01-18-2008, 03:48 AM
Stainless
You can get a full 3D package from Pro/E for $300 for hobby use at Journeyed.com.
Chris P
01-18-2008, 11:32 AM
Hot Rolled
www.deltacad.com has a nice shareware cad system that alot of the guys at theshop use for simple 2d drawing. you can teach yourself cad in a couple of hours with it. they ask you to buy another version of dcad but the only differance i think is you can put a legend at the bottom.
01-19-2008, 07:44 PM
Cast Iron
DeltaCAD $50
I just purchased the regular version of DeltaCAD. It is slightly crude in some ways, but not nearly as crude as the extremely lame example drawings on their website might lead you to believe. It is the easiest and best thing I've found in the U.S., for my needs as a machinist. One of the key things I like is that you can instantly get the X/Y coordinates for a point on your drawing. Then it is not too hard to select and shift your whole drawing to bring that first point to zero/zero. Then you can get the X/Y coordinates, relative to that, for every corner, hole center, radius/line intersection, and radius/radius intersection in your drawing very easily. This was the most important key feature for me, to use for manual programming of CNC equipment. Also useful for manual machining, if you have a DRO on your mill. It is handy for working drawings to have the X and Y for each feature on one line, all relative to some logical base corner or other point you selected, rather than chasing conventional dimensioning all over the print.
I was using something called CAE2D in Japan for this same purpose, which was far better. It had many more useful features crammed into fewer onscreen buttons, and what you wanted to do just seemed to appear when you needed it. Very intuitive, and apparently designed especially for machinist use. But it was all kanji, so I still needed frequent help learning it. I was probably just scratching the surface of its capabilities, but I loved it. However it is illegal to export that to America, and extremely costly to buy anyway.
I tried several other 2D CAD programs in the U.S. but I could barely make any drawing at all on most of them, much less find the required X/Y coordinates.
02-22-2008, 03:23 AM
Solid Edge Free 2-D
Here is the link for Solid Edge 2-D (free)
http://www.plm.automation.siemens.co...2d/index.shtml
And a quote from their website:
Solid Edge 2D Drafting (for FREE)
Whether you are using 2D across your company or for a specific 2D design process, Solid Edge 2D Drafting will give you an immediate advantage with production-proven capabilities including drawing layout, Goal Seeking, diagramming, and dimensioning. It is fully compliant with ISO, ANSI, BSI, DIN, JIS and UNI, and it's absolutely FREE to download and use.
Solid Edge 2D Drafting eases the transition from 2D AutoCAD with import wizards, matched fonts and color schemes, XREF support, paper/model space support and much more. Get up to speed faster with a built-in Command Finder - never look for AutoCAD equilvalent command again.
Solid Edge 2D Drafting requires Windows XP or Vista and now includes the Free Solid Edge Viewer. Make sure you have Internet Explorer version 6.0 or later for the download.
02-23-2008, 02:39 AM
The Solidworks version is not half bad either.
http://www.dwggateway.com/
Enjoy.
03-03-2008, 06:24 AM
GStarICAD is worthy your trial use
If you are looking for the costly 2D CAD software,I would like to recomend those CAD software belong to ITC,which is a low price,but the performance is ok if you just take the drawing as hobby.( http://www.staricad.com) GStarICAD is a good CAD software among ITC,you can have a try
03-03-2008, 12:57 PM
SolidWorks if you can afford it. It seem to be the way most shops are going these days.
03-03-2008, 04:26 PM
DesignCAD and ContourCAM
Hi John,
I'd like to recommend one of the DesignCAD products. They are pretty cheap, and most importantly they ar easy to learn.
DesignCAD v. 18 is the 2D product and it comes at $49.95.
DesignCAD 3D MAX v. 18 is the 3D version, which comes at $99.95.
Should you later find that you need a CAM system, ContourCAM is a comprehensive DesignCAD plugin.
You may find information on the DesignCAD series here:
http://www.imsidesign.com/Products/D...1/Default.aspx
and a trial version of DesignCAD 3D MAX v. 18 here:
http://activate.imsisoft.com/freeen.aspx?Product=D3M18
and information and trial version of ContourCAM here: www.contourcam.com.
Hope this helps.
03-07-2008, 01:06 PM
There is always paper and pencil.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Powered by vBulletin® Version 3.8.2 Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
