Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > CAD / CAM
CAD / CAM Computer aided design/ manufacturing software issues
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 03-16-2009, 02:56 PM
RJT RJT is offline
Hot Rolled
Default Convert cadkey .prt to autocad .dwg
New customer uses Cadkey, is there some utility I can use to convert them? Trying to make it painless for the customer. RJT
  #2 (permalink)
Old 03-16-2009, 03:25 PM
Stainless
In Cadkey I think they should be able to pick: Files, translate, export, dwg. to send you a dwg. file instead of a prt. file. That might be the easiest if you don't mind asking them for a easier file for you to work with.
  #3 (permalink)
Old 03-16-2009, 03:35 PM
beege's Avatar
Hot Rolled
I think it's easiest for them to "Export/dxf" but that's just me... as for your in-house translator from .prt to dwg, you contact Kubotek and see if they have any conversion utilities. They used to when it was just Cadkey.
  #4 (permalink)
Old 03-16-2009, 10:27 PM
Default File export dxf.....
The best way may be to simply export the files as DXF or DWG from cadkey, it is really painless for the customer also.
Depending on the cadkey version you should expect the file to be an old version like autocad 12 or something like that. If the file is exported from cadkey as a dxf, I have had no problem using it to get geometry. I have not tried the IGES export from a cadkey solid, but have seen it kind of work...
  #5 (permalink)
Old 03-17-2009, 09:07 AM
Default Cadkey files
RJT,
How many files are there? If there's just a few, send them over and I could do them for you. I understand not wanting to ask the customer.
depryor@davidwolfedesign.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
