Face Milling a Slant
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Dec 2017
    North Carolina
    39
    20
    7
    Default Face Milling a Slant
    Good morning everyone.
    As you can by my past post, I am somewhat new to CAM. I am trying to figure out the best way to face mill a slant. The material is aluminum. I am using a HAAS five axis machining center and I'm progrsmming using InventorHSM with HAAS automation post processing. Thank you in advance for any info on this.
  2. Likes TopSolidCAM... liked this post
  3. #2
    Jun 2012
    Michigan
    3,526
    2910
    2041
    Tilt to the plane the slant is on and facemill it?
    I assume HSM Inventor has that capability.
    Dec 2017
    North Carolina
    39
    20
    7
    Quote Originally Posted by Mtndew View Post
    When you at "tilt to the plane" do you mean rotate the part to where that slant is level? I am not sure I understand.
    Jun 2012
    Michigan
    8,341
    2477
    2776
    Tilt table is one method
    HAAS VF-5 4 Axis CNC Swarph Milling with a 5th Axis Trunnion Table - YouTube
    Simplify 3+2 and 5-Axis Machining with DWO/TCPC – Haas Automation Tip of the Day - YouTube
    My experience is in CNC grinding not milling .. If unsure of direction then jog a little to see the right way .. take care that tool change will not crash with things tilted.
    Jun 2012
    Michigan
    3,526
    2910
    2041
    Quote Originally Posted by cmmpro1 View Post
    How much experience do you have running the 5 axis mill? It sounds like you need some training, the answer I gave you is very basic terminology.
    Dec 2017
    North Carolina
    39
    20
    7
    Very little!!! I'm a cmm programmer. I got moved from quality because I have machining experience. I'm sorry for asking basic questions but I'm trying to learn.
  8. Likes Mtndew, michiganbuck liked this post
  9. #7
    Jun 2012
    Michigan
    8,341
    2477
    2776
    Sounds like you need to be very careful. Do a little studying and not break the machine.
    Basic questions are fine. I would have to do the same, and would not touch that machine if not very sure.
  10. Likes cmmpro1 liked this post
  11. #8
    Dec 2017
    North Carolina
    39
    20
    7
    Quote Originally Posted by michiganbuck View Post
    Thank you! Lol. I am standing here looking at this like a deer caught in headlights!!!
  12. #9
    Jun 2012
    Michigan
    3,526
    2910
    2041
    In that case, the first thing I would do is watch a shit ton of YouTube videos to see the ins and outs of how a 5 axis machine works and I'm sure there are videos on HSM Inventor as well. Granted some videos are cutting very complex parts but you might pick up on something.
    When I say tilt the plane that the slant is on, your programming software should have the option to create a new plane, then you orientate that plane so that the slant is facing up. Create a facing toolpath and you are off and running.
    Setting up the machine is a whole different animal, are you responsible for that too? Or do you have a setup guy?
  13. Likes michiganbuck, cmmpro1 liked this post
  14. #10
    Dec 2017
    North Carolina
    39
    20
    7
    I have a guy that does all the setups. All I have to do is write the programs and pull the stock and tools. Sometimes, on the other machines, I make some edits in the program but I normally let the operator do that unless he or she isn't sure. I still have to write cmm programs for our one offs and FAIs.
  15. #11
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    Use Tool Orientation on the Geometry tab to orient the Z-axis in line with the tool/spindle.
    Will see if I can find a video on that when I have time.
  16. Likes cmmpro1 liked this post
  17. #12
    Dec 2017
    North Carolina
    39
    20
    7
    Quote Originally Posted by Atomkinder View Post
    Thanks AtomKinder!!
  18. #13
    Dec 2017
    North Carolina
    39
    20
    7
    Also, in doing this, I could either use swarf or multi-axis contour, correct?
  19. #14
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    Without seeing the part geometry I'm not sure. It's likely possible, but if you want to use a Face toolpath, Orientation is your best and easiest bet. Multi-axis Contour is a weird one to get right on some things as it is more like a Trace toolpath, so if you have the clearance, Swarf is better.
  20. #15
    Sep 2013
    Minnesota
    147
    13
    27
    So many question marks here...
    Do you have other programmers at your site you can ask a few questions to show you some things? Seems like you are getting into Training 101 so I'm curious if you can leverage your company's knowledge and experience rather than reinventing the wheel; just to get you going of course and then proceed from there.
  21. #16
    Dec 2017
    North Carolina
    39
    20
    7
    Quote Originally Posted by Qwan View Post
    I wish I could ask him but he's not approachable. That's why I come here or figure it out for myself. The company isn't willing to provide training. They say its not in the budget so I'm basically on my own with this. I knw that its hard to get info out of some machinists so I will keep my questions to a minimum.
  22. #17
    May 2012
    Mid-Iowa, USA
    3,554
    3453
    2049
    I would suggest heading over here: HSM - Autodesk Community
    That's the official support forums for HSM, and you can attach files, and there are usually several members paying attention. It's a good community.
  23. #18
    Sep 2008
    934
    545
    513
    i don't have 5-axis, only 3-axis, so
    1) if it's a block with parallel sides I might put it into a vice and use an angle block or sine bar to indicate it to the correct angle. If I had to do a lot I might cut a dedicated angle block that sites in the vice.
    2) put a vice on a sine plate and set it to the correct angle. I have various sine plates for vices/large parts.
    You know if you crash the 5-axis who's going to get the blame? Be careful!
  24. Likes cmmpro1 liked this post
  25. #19
    Dec 2017
    North Carolina
    39
    20
    7
    Quote Originally Posted by triumph406 View Post
    Thank you!!! That's what I ended up doing, I did it on the three axis and set up the sine plate. He originally wanted me to put it in the 5 axis but I didn't feel comfortable with doing that. I saw one guy crash one........ Hadn't seen him since.
  26. Likes triumph406, michiganbuck liked this post
  27. #20
    Sep 2008
    934
    545
    513
    Cool! Glad it worked out!
  28. Likes michiganbuck liked this post
