You are correct on all counts Seymour!
I will add a little bit to help the masses understand the difference between how tool-path is driven between the two.
In MasterCAM, you "chain" your geometry to create tool-path. In FeatureCAM, you create "curves".
This curve creating is essentially the same as chaining in M-CAM. But better. Not only is it easier, and quicker. It is far more versatile. You don't need solids. I have made some pretty dang complex stuff in F-CAM with simple geometry. But, if you have a solid, it's just that much faster.
And if you are savvy with using different layers (think levels in M-CAM) you can keep a very organized, easy to look at, part file.
Drawing (geometry creation) in F-CAM is way-way-way easier/faster. F-CAM in general is way faster.
M-CAM can give more infinite control over the actual tool-path. And, fine tuning that control is a little easier.
One of the biggest pluses M-CAM has over F-CAM? The tool-crib! F-CAM does some really stupid shit with their cribs.
Having used both, my opinion is: in a shop that does a lot of "new" parts, F-CAM is the way to go. Simply because it is faster.
Run a lot of production? Big volumes where every second of cycle time counts. Even if you have to spend more time at the software tweaking?
M-CAM will let you tweak precious seconds out way easier than F-CAM.
Price? I don't know these days.
I am up to about $14k. And, historically my maintenance has been a fuzz over $1500/yr. But, I have full 3-D, 4th-axis, and turning. They don't give that great of a discount on a second seat either.
They do have two different levels of 3-D. Full 3-D, and 3-D "light". The light will do basic stuff. But it is pretty limited.
I ran a trial of light for a couple weeks. And, quickly determined, I needed the full option.
Seymour is again correct though, they are going subscription based very soon, if not already have. Not sure.
Older perpetual licenses are grandfathered in, from what they explained to me. As long as I keep maintenance current.
Edit: I just thought of one other HUGE benefit of F-CAM. Running the same thing across multiple vises? Or fixture stations?
F-CAM handles this with a "multiple fixture document". And this process is soo far ahead of M-CAM's technique, its not even funny.
Wheelie, I follow your posts because I respect what you have to say on
most things. So don't take this as an attack as I have asked this kind of thing before. I don't know how much easier Featurecam can be in posting multiple work offsets/parts? In Mastercam it is transform toolpath (hang on, opening part so I can do it and see exactly...). Ok so opened a part that I previously programmed, will count the clicks I need to do for reference.
1) click on toolpath group 1 (selects all toolpaths in that group)
2) click toolpaths>transform (could shorten one click if I were to make an icon for the transform toolpath)
2b) to note, by my default settings, which are user configurable, the transform toolpath comes up with my operations selected (which I did in step 1), type set to translate, method set to operation type, work offset numbering set to off.
3) select options such as rectangular (most often used IMO), number of instances, and a pattern if needed.
3b) in my sample I did I changed 5 input fields - changing number of transforms, X distance, Y distance, work offset numbering, and operation order
Now I get if you are not familiar with the options it might sound like alot, but for my most often used scenario at the current job, almost everything comes in at the default so I change about 4-6 variables. Now to be perfectly honest here, I could set my default transform toolpath to reflect all the changes I made, meaning I could select transform toolpath and be done, BUT, I am surely not always going to run 4 parts for example. Probably the most important, biggest, point I need to make about this is - SET YOUR DEFAULTS!! Probably the biggest time sink, not just in Mastercam but every software, is
A) user does not learn it properly (been beat to death I know)
B) user never bothers to configure software to best suit their needs
Now I will say, if you are trying to squeeze seconds off your cycle time, the translate toolpath has to be used a little differently. I.E. takes alot more time to insert at key spots in your programmed toolpaths. Also, the transform toolpath can be used for rotation too, so if are doing rotary parts with repeating features it is very handy.
The example I somewhat explained was basically taking a fully programmed part and translating it to another work offset. It can also be used to translate identical features in a part. I am running parts like that now. I programmed one feature, then used the transform to copy it multiple times. I am not trying to beat up featurecam as I have never used it, downloaded the free trial a while ago but got busy and never got a chance to do anything but play with it.
Oh yeah, you said you have 14k in it so far, does that include all the years of maint you have paid, or was that to buy the initial package? I got a quote for MCX recently and it was 12k for 3 axis ONLY!!
