Fusion 360 and 4th Axis Issue--STUMPED!!
Results 1 to 13 of 13
    Nov 2017
    Mississippi
    6
    Question Fusion 360 and 4th Axis Issue--STUMPED!!
    We just got a new HRT160 4th axis for our Haas Mini so my experience level with 4th axis in general is pretty low. My issue is this,
    My first project for using my 4th axis is basically a cube with the same machining being done on each of the rotating sides. In F360 under Pattern, I use "circular pattern" with 4 instances. The code starts off with a facing operation, several milling operations, followed by a couple drilling operations to be repeated on all 4 sides.
    For some reason the facing and milling operations would all move to a safe Z height before the A axis rotates the part. Once the drilling cycle starts it would run correctly on the first side, then go up to the retract height but would drop back down to machine zero (tool change height) before the A axis starts rotating, which doesn't allow for enough clearance. First I tried adjusting the clearance/retract heights but this a no effect on the Z axis prior to the A axis rotating. So then I started analyzing the code and was surprised that the end of cycles between the milling operations and the drilling operations were identical. I cannot find anything in the code that would make the drilling operations return to Z zero before rotating the A xis but does not require the milling operations to do the same. I have even tried separating the drilling operations into its own program, still has the same results.
    At this point I dont know if its a F360 setting or a HAAS setting that is causing the issue.
    Thanks in advance for any help.
    Keith
    Apr 2015
    Connecticut
    213
    125
    97
    Posting the code may help. I don’t know anything about a HAAS but you might need to cancel your canned drilling cycle prior to moving your fourth axis to move your tool to a safe height. From what you said if the cycles end the same for drilling and milling then there must be something built into your drilling cycle that screwing things up and you might have to cancel it out first.
    Apr 2013
    New York
    713
    597
    570
    Check your post processor - it may depend on the year of your Mini, but the max Z height probably isn't 0, it's more like -4, meaning you have 4 inches of Z travel above the toolchange height.
    Most post processors I've seen for 'Generic Haas' send Z to zero before rapids, toolchanges, etc. The problem on a Mini being that's not as high as the machine can go, which can cause weird crashes (i.e. finish a drilling cycle, go to a correct, safe retract height, then go back to Z0, putting the drill in the hole, and then moving X or Y, breaking off the drill.
    Minis have extremely limited Z as it is, which is why many folks who are going to use theirs for 4th axis work get the 'Extended Z' option, which spaces the Z axis up 4" (or maybe it's 6"?)
  4. Likes Whysosharp liked this post
    May 2014
    Los Angeles
    350
    65
    Hello.
    Perhaps this will help 3+2 Programming in HSMWorks Part 1 - YouTube . I think we had similar issues and fixed them with these videos. It was a while ago so I dont remember what we did but we watched this.
    EDIT
    3+2 Programming in HSMWorks Part 2 - YouTube so towards the middle of this video he talks about it. Maybe you need to select the reversal of the z axis or change the way you are paterning it. He uses seed.
    Nov 2017
    Mississippi
    6
    Thanks for the info, I will definately look into that stuff.
    Whysosharp, I tried to post the code but PM has a limit on the amount of characters in a post.
    JohnnySolidWorks, I can definately see this being the issue, thanks for the direction
    Plutoniumsalmon, Thanks as well, videos are always a good thing, I'll check them out.
    Apr 2015
    Connecticut
    213
    125
    97
    Excellent point Johnny. two of our supermaxs have a tool change height lower than z zero similar to how the mini mill may be.
    May 2012
    Mid-Iowa, USA
    3,545
    3446
    2046
    You can also head over to the Fusion 360 CAM forums if you need more directed help. It supports uploading files like exported projects which can be really handy for a direct perspective of any issues you're having.
    Fusion 36 Computer Aided Machining (CAM) - Autodesk Community
  9. #8
    Nov 2017
    Mississippi
    6
    Not sure if I'm allowed to do this but I posted the same question on ******* before posting here which did allow me to post the code. So HERE is the link if anyone wants to check out the code.
    Sorry if posting links is not allowed.
    Keith
  10. #9
    May 2012
    Mid-Iowa, USA
    3,545
    3446
    2046
    Well from what I can see (the links are not allowed but it was easy to find) all the operations that require an A-axis movement return to G53 Z0. which is standard behavior in the generic Haas post. This can be changed, but requires a post edit.
    Again, I'd suggest hitting up the Fusion forum. Your Autodesk login should already work for the site.
  11. #10
    Apr 2013
    New York
    713
    597
    570
    Yep, looks to me like the standard end of the block added by the post processor of G53 Z0. is what's getting you. CAM knows the safe retract height for the tool relative to the workpiece but the machine Z0 is below that because of the unique Minimill Z heights.
    If you do a "find and replace" (or even just manually search and replace) those Z values, which should only be right before tool changes or A axis moves, and replace the Z0 with a safe height, you should be fine.
    Haas has a YouTube video for how to alias an M code for safe tool changes with a 4th axis in the machine which will also help with this, and prevent the next problem you're going to have with a 4th in a Mini.
  12. #11
    Nov 2017
    Mississippi
    6
    Atomkinder, So if I understand this correctly, since the G53 Z0 is the same for the milling runs as well as the drilling, I'm only noticing it on the drills because the bit happens to be too long to clear the fixture as the A axis turns at Z0? I'm out of the office today but will check that tomorrow morning.
    Johnny Solidworks, I thought I tried replacing them on the drilling runs and if I remember correctly the machine through an error, but I'm not positive thats what I was doing. Now that I'm alot more familiar with what is going on I'll look and try that in the morning.
  13. #12
    May 2012
    Mid-Iowa, USA
    3,545
    3446
    2046
    Quote Originally Posted by LockTech View Post
    Bingo.
    FWIW I have added a retract modification option to the HSM post processor before, it's not difficult. Not difficult to add a tool change position if needed also.
  14. #13
    Oct 2013
    New Jersey
    737
    612
    It amazes me how no one is bothering to learn a little G-code so they can troubleshoot a problem like this. Years ago my replacement came in the door dragging a computer loaded with MasterCam. I was programming castings from 50 year old paper drawings using parametrics so I could get the job done quickly hand coding. He didn't have a post for our machines and expected the operators to change tools by hand! Wouldn't run any programs I wrote because he couldn't read G-code to see how they worked. Heard he lasted about 3 months.
