just I have always seen you say how good mazatrol is I am surprised you posted this topic.
Mazatrol is great for a lot of job shop machining, but it does have limitations, especially in complex milling. For 2-axis turning, and most live-tool lathe work, Mazatrol is hard to beat. Once your experienced with it, you can literally program lathe parts as fast as you can punch the program in. Even complex 2-axis parts can be programmed in minutes.
For 2.5-axis milling, Mazatrol is pretty powerful as well. Although as your part features get more numerous, so do your programming units, so you begin to lose efficiency with Mazatrol on the more complex milled parts.
So I would say for probably 75% of job shop turning and milling, Mazatrol is a fantastic programming system. A whole lot of machine shops were built using Mazatrol, and it's the primary reason Mazak became the largest machine tool builder - dollar wise. (Haas is largest for number of units sold.)
I have always programmed at the machine, and again, for a job shop that's not necessarily a bad thing. Why? Well, you're there at the machine, not only programming but finding and inputting tools, scrounging up a fixture/vice jaws, getting the job set up with what you have to work with.
Being out in the shop and at the machine can be an asset as you create your setup. Often your program will have to be modified based on what tools you have available, or how you're having to process and hold the part.
And once you start walking your program through and running parts, an experienced Mazatroler can tweak feeds and speeds and toolpaths to create a very efficient program, all the while running parts and getting the job done.
Of course Mazatrol will not do 3d surfacing, so if you want to do that then CAD/CAM is a must.
I want to be able to draw parts using solids, and create programs to machine these parts fast and reliable. I would use the CAM primarily for milled parts, as like I say, for turning Mazatrol is a great solution.
As of now I am leaning towards Fusion360, and look forward to playing with the software and increasing my shop's capabilities. In my region, most shops are not truly "CAD/CAM" capable, meaning they don't have the ability to quickly create a solid model and then a cnc program to produce the part. Having this capability can set me apart, and now with Fusion360, it's within reach and affordability of even the smallest cnc shop.
Thanks for all the replies!
ToolCat
