Help with programming and machining this part
tline
Dec 26, 2017
I need help programming the angled face end of this part.
Any advice appreciated.
  • Die machining line.pdf
Mill? Lathe? What have you tried so far? What do you need help with specifically?
Way, way too open ended for anyone to be able to help you.
exactly what i was thinking! if it is on a lathe i would use a LH dnmg set up for facing but there are a lot of options on how to do it, flip a boring bar over, trepans, etc.
I need to make 20 all slightly different.
I thought turning would be quicker but I don't know what tooling to use.
The part is 316 stainless steel.
I have tried in HSM works but again it will not accept a boring bar.
i had never heard of hsm works until today but i looked it up and it looks like the program is calling it a 55 deg diamond which i have a bad habit of calling a dnmg since that is pretty much all i use.
Hello tline,
I would use a Boring Bar similar to that shown in the attached picture; all you need is an approach angle that will give clearance on the angled face. No need to flip it, just set it as a conventional B/Bar.
The example code is for a 0.8 TNR. DOC is conservative, as this insert shape and approach angle doesn't give a great cutting action with a DOC much over the TNR size when face cutting from small to large Dia.
Regards,
Bill
Code:
(55DEG. DIAMOND 0.8 TNR BORING BAR 100DEG APPROACH ANGLE)
N1 G00 X-0.400 Z3.000
G01 Z1.000 F1.00
G01 Z0.260 F0.20
G01 X30.246 Z-1.350 F0.25
G01 X139.700
G01 Z-1.050
G03 X142.100 Z0.150 I1.200 K0.000
G00 Z2.200
G00 X30.147
G01 Z-1.345
G01 X58.793 Z-2.850
G01 X139.700
G01 Z-1.350
G00 X58.693
G01 Z-2.845
G01 X87.340 Z-4.350
G01 X137.373
G01 X139.700 Z-3.186
G01 Z-2.850
G00 X87.240
G01 Z-4.345
G01 X111.700 Z-5.630
G01 X134.813
G01 X137.373 Z-4.350
G00 X137.373 Z2.200
(FINISH PASS STARTS HERE)
G00 X142.100 Z2.200
G01 Z0.000 F0.20
G02 X140.000 Z-1.050 I0.000 K-1.050
G01 Z-3.249
G01 X134.937 Z-5.780
G01 X111.684
G01 X-0.400 Z0.109
G00 Z2.200
Thank you Bill.
Much appreciated.
Mike
Hello Mike,
If you were to use a Face Roughing cycle, such as a G72 cycle for a Fanuc Control, you only need to program the profile path and you can then play around with the DOC using the parameters of the cycle without having to re-post process the program.
Regards,
Bill
