How do i convert a metric file and all toolpaths to inch in gibbscam?
markp
Hot Rolled
Oct 7, 2006
Petaluma CA 94952
Trying to convert a metric gibbscam file to inch and also convert all the toolpaths at the same time. I looked in the user manual and searched online and seems theres no way to do this that is documented. I see how to import a metric part and use shrinkwrap but no info on doing this with an actual gibbs file. Anyone know the trick?
just switch your CNC over to metric is the easiest and run the parts.
Yes, some gibbs posts can output either, this is a custom 5 axis post and it only outputs what is set in part setup dialog. In the post dialog, the in-metric buttons are greyed out.
there should be a radio button in the post process dialog to choose output units regardless of file units.
