How are you programming 5axis trunnion with turning options?
Results 1 to 11 of 11
    Jan 2012
    Savannah, Georgia, USA
    1,643
    2602
    597
    Default How are you programming 5axis trunnion with turning options?
    We have a okuma 6300 5x AC trunnion mill with the "turning option." The C axis table spins at 1200 rpm I believe. I use mastercam. In mcam you can call up a mill or a lathe, or a mill/turn with a B axis, where the spindle head rotates right? But I am not familiar with this style of programming. I guess I could just program like a simple lathe and manually insert the A axis rotations and mcodes needed to spin the table. But...
    There is a post available for this machine from Impostablilty and maybe this opens up the options.
  2. Likes TopSolidCAM... liked this post
  3. #2
    Jan 2012
    1,643
    2602
    597
    150 views and nobody doing 5x turning?
    Aug 2009
    FL
    66
    MC is doing this type of programming. If its an Okuma, the Partner in Thinc group have a MC guy, CHRIS KOZELL, on site in Charlotte that be should be to help. Call your Okuma dealer/AE they can connect you up.
    CAD/CAM, CAD, CNC Software, Mastercam, Partners in THINC
  5. Likes bryan_machine liked this post
  6. #4
    Mar 2017
    6
    5
    Topsolid
    Sent from my HTC6515LVW using Tapatalk
  7. #5
    May 2013
    Near Seattle, WA
    1,015
    256
    818
    Quote Originally Posted by lowCountryCamo View Post
    I don't really see where this style of machine is significantly different than any other mill/turn combination. I'm not programming one, but the building blocks seem functionally the same.
  8. #6
    Jan 2015
    501
    80
    253
    Quote Originally Posted by rlockwood View Post
    I read the post as he is questioning how to do it on the CAM side, not necessarily if the machine is capable or not.
  9. #7
    May 2013
    Near Seattle, WA
    1,015
    256
    818
    Quote Originally Posted by thesidetalker View Post
    That's what I mean, though.. It's just a matter of stitching together of some turning code with some milling code, right? I can see, similar to a b-axis turning center, wanting some better simulation capabilities, particularly around the definition of the toolholding, which varies quite a bit from standing stick tooling. Otherwise, it would seem like a simpler problem than your average b-axis, two turret turning center.. which leaves a few decent options on the table.
  10. #8
    Mar 2012
    Northcentral Pennsylvania
    64
    6
    26
    Not a whole lot of help given that you are asking in the CAD/CAM forum, but I'm working with MU-L's. I've just been programming them by hand. Turning function supports LAP cycles, tool nose radius comp & grooving. I've never been into using CAM for turning, so it wasn't that much of a jump for me when I got onto it.
    Are you using turning function at all now? PM me your email if you would like, I'd like to compare notes on the turning function and may be able to help out if you are just getting started.
    Lance
  11. #9
    Jan 2015
    501
    80
    253
    Wonder what the code looks like to do that. How is the offset of the turning tool from spindle centerline compensated? Handled at the machine control? Or the offset calculated from CAM? TCPC is neat stuff.
  12. #10
    Apr 2012
    UK
    20
    7
    This isn't something I have done but I have programmed both 5x and turned with Hypermill, is easy enough to create both types of programs and you can create both in the same session, so imagine it would work pretty seamlessly.
    and looks to work pretty well here
    5 Axis Machining: The Puzzle Ball - programming of milling and turning | hyperMILL | CAM | DMG - YouTube
  13. #11
    Dec 2014
    98
    11
    11
    I have seen two companies with posts like this. The best one was made by Dave Thompson. I highly recommend calling him up.
    Pretty seamless and easy, just program in Mastercam lathe as you would normally.
    [email protected]
