Inverse time, Fusion 360
Community On The Web
Results 1 to 13 of 13
    Dec 2002
    Pacific NW
    4,800
    7
    659
    Default Inverse time, Fusion 360
    Looking for a post processor for 4th axis on a Centroid control since the supplied generic Centroid post doesn't do multi-axis work.
    Trying the supplied Fanuc A-axis inverse time post it gave a feedrate of "F128". Doing the same thing with a Haas A-axis inverse time post the feedrate was "F611.".
    Using the Centroid calculation method I came up with "F625". Considering rounding errors in my quick calculations Haas and Centroid use the same method.
    What's with Fanuc and do other controls use even different methods to calculate inverse time?
    May 2011
    CANADA
    Saskatchewan
    509
    301
    222
    If you do find one that produces the correct A-axis results, it would be super easy for Autodesk to copy that feature into a modified Centroid post for ya, I would suspect. They have been helpful with our post modifications.
    Dec 2002
    Pacific NW
    4,800
    7
    659
    Quote Originally Posted by apoc_101 View Post
    Thanks for the reply.
    I was hoping that. Last week I posted on the Autodesk post processor forum about getting a Centroid 4th post. No response yet. How did you make a contact with the people capable of writing or modifying posts?
    Dec 2002
    Pacific NW
    4,800
    7
    659
    I got a reply from Autodesk, apparently they don't do custom posts, only generic type. They did give me a list of resellers who could customize a post. I guess you can't expect too much for nothing.
    Dec 2008
    tempe,arizona,usa
    1,480
    85
    144
    Did contact the Fusion forum or the HSM forum?
    Dec 2002
    Pacific NW
    4,800
    7
    659
    Quote Originally Posted by len_1962 View Post
    I followed a link that seems to have taken me to the HSM forum in the Autodesk Community. Maybe the wrong place, huh?
    At any rate I did find a post that (sort of) works. It's the Haas inverse time A axis post supplied with the Fusion download. I haven't run the code yet, but it seems to be correct format for Centroid.
    What's strange about the Haas post is the output when a circular contour is wrapped onto a 2" diameter round. The A axis rotation spans about 70 to -70 degrees in this case. All the feedrates are the same from 0 to 30 degrees (and 0 to -30) then the feed abruptly doubles from 30 to 70 degrees (and -70). Code is shown below, note it's inverse time so higher number is slower. I checked in CAD to verify and it appear after 30 degrees the increment length from N59 to N60 is doubled from N61 to N62 reflecting more time needed to feed that distance.
    N57 X1.2871 A25.574 F820.649
    N58 X1.2805 A26.549 F820.648
    N59 X1.2733 A27.512 F820.647
    N60 X1.2661 A28.475 F820.646
    N61 X1.2507 A30.375 F410.335 ; feed change here
    N62 X1.2344 A32.248 F410.334
    N63 X1.2171 A34.093 F410.333
    N64 X1.1988 A35.907 F410.332
    N65 X1.1796 A37.688 F410.332
    Apr 2010
    Wisconsin
    4,500
    3546
    2177
    Not to deride from your intent, but are you actually able to get real 4 axis simultaneous tool paths, or are these for something else? I ask, because I dropped fusion for its lack of 4 axis ability that contradicted what the advertising said. So I would be interested in hearing if you are actually using some.
    Jan 2005
    CANADA
    Saskatchewan
    8,515
    793
    2395
    Quote Originally Posted by Doug View Post
    I don't know what math is used in the post, but it has to calculate the length of every vector and the circumference of every arc, in order to deduce the time duration of the move. When I see a sudden doubling like that, at 30 or 60 degrees, I think of the effect of sine or cosine. So I think the formula being used is off track.
    May 2005
    Vancouver, WA
    464
    17
    If you multiply the move length by the inverse time feedrate you will get the linear feedrate. Based on the code you posted your programmed rate was 15 ipm. Is that right?
    I'm not sure why the move lengths double, but the feed stays fairly consistent.
    Dec 2002
    Pacific NW
    4,800
    7
    659
    Quote Originally Posted by Zahnrad Kopf View Post
    As I said I haven't run the code. I have hand coded enough simple 4th axis simultaneous tool paths to know the code looks good.
  11. #11
    Dec 2002
    Pacific NW
    4,800
    7
    659
    Quote Originally Posted by CPT Crunch View Post
    You're right the feed rate was supposed to be 15 ipm, and I also noticed it calculated backward to come to that rate.
    Where there could be a problem is by increasing the segment length the output may not be in within their accuracy tolerance. That little popup box in the lower right of the post process operation it says "(built in) tolerance .002". If that's changed to .001, the code is the same.
    Another puzzle.....when I tried the supplied Fanuc inverse time post the results were more what you would expect. Each line has a slightly different calculated feedrate, all within a range of about F170 to F190 up to 30 degrees. It does the same change of the feedrate at 30 degrees though. Fanuc must calculate inverse time in different units because where Haas is in the F820 range Fanuc is in the F180 range.
  12. #12
    May 2013
    Near Seattle, WA
    889
    185
    704
    Just popping in, and haven't done my due diligence reading here.. A quick glance shows the haas post is dividing the toolpath into equalized segments; the segments @ 410 ipm are roughly twice as long as the 820dpm segments. Most likely, the fanuc post is just segmenting differently, or not at all. In other words, both are probably correct.
    The response you got on the CAM forum was from an Expert Elite, not from Autodesk themselves.. but it is still rather accurate. OTOH, if you're using an existing out of the box post, and it's lacking functionality that the MTB/control offer, it's entirely possible they'd gladly implement it into the out of the box post. The tricky part is usually finding someone who can reliably define the work that needs to be done, and test it to verify they're not pushing out garbage to a ton of customers.
  13. #13
    Dec 2002
    Pacific NW
    4,800
    7
    659
    Quote Originally Posted by rlockwood View Post
    Thanks for making the point. Yes, you're correct, I forgot to mention this. From memory, the Fanuc post is segmenting a bit shorter increments, taking that into account I still didn't see any correlation between the feedrates.
    Makes you wonder for the same model why the segmentation is different, huh? Different individuals writing the posts maybe?
    When I get time I'll check into this a little deeper.
    I'm not depending on Fusion for anything other than personal interest, other software handles my needs.
