Been struggling with this on a few programs over the course of a couple months - lathe grooving tool isn't following the chain I tell it to, it will offset one side or one wall of a groove by about .020" no matter what. For instance, this morning building a grooving path for a .086" wide groove with an .062" wide insert...first toolpath fails because I can't leave any more than .002" finish on Z. Take the stock left on rougher down to .000 and it will rough and then follow the (Z-) chain in X, come back out and finish the (Z+) chain in X, but the entire contour will be offset to (Z-) by .020".
Just figured out a "fix" for the issue a few moments ago - edit the grooving insert, take the corner rads off completely, regenerate path, then toolpath runs just as I want it to. Go back in, add proper corner rads, regenerate...and the toolpath runs just as I want it to.
Anyone else seen this? I'm glad I know how to operate around it now but it'd be nice if there was a proper fix to where, I don't know, it wasn't happening at all anymore.
