mastercam 2017 waterline from outer stock boundary
Results 1 to 8 of 8
    Sep 2017
    South Carolina
    Default mastercam 2017 waterline from outer stock boundary
    I'm a bit new to milling in mastercam and could use some help to get the outer part profile cut. What I would like to do is have the part cut by following the part profile from the outer stock boundary inward with constant Z slices using the side flutes of the end mill. What I have now is a waterline cutting a channel in the stock following the outer stock boundary. After trying this on the CNC yesterday friction started building up around the top section of the channel and the shank of the end mill as the program got past the 1" flutes. Also, this method started to wear the bottom of the end mill. For the center hole I am using a helix cut starting from the part origin moving inward. The center driving surfaces are divided in two with 0.005" difference in diameter between the upper and lower cuts to clear the shank of the end mill. Material is S7 Tool steel 7" OD and I am using a Hass TM2.
    Center hole path.
    Waterline path.
    Current part.
    Mar 2013
    Eastern CT, USA
    206
    116
    78
    If I understand your question correctly, waterline would be ok to finish the part perimeter but not necessarily the most efficient path to use. I would use 2D contour path. With that path you can set the depth to use more of the flutes and use multi passes to address step over. As far as the cutter heeling when you get past the LOC, either relieve the cutter .002"/side for clearance or buy cutters already relieved for that purpose.
    Joe
  3. Likes J Gilles liked this post
    Nov 2013
    Chippewa Falls, WI
    38
    348
    16
    [[email protected];3047753]If I understand your question correctly, waterline would be ok to finish the part perimeter but not necessarily the most efficient path to use. I would use 2D contour path. With that path you can set the depth to use more of the flutes and use multi passes to address step over. As far as the cutter heeling when you get past the LOC, either relieve the cutter .002"/side for clearance or buy cutters already relieved for that purpose.
    what Joe said. Unless there's some draft I'm not seeing, a straight up contour will be the best way to get this done
  5. Likes J Gilles liked this post
  6. #4
    Mar 2015
    Michigan
    244
    33
    61
    I'd try to rough that out using the dynamic mill path. With your stock setup I think it would result in something with a lot less wasted time that just going with a 2d contour with multi passes.
  7. Likes J Gilles, Mtndew, mhajicek, lowCountryCamo liked this post
  8. #5
    Mar 2015
    Michigan
    244
    33
    61
    Hopefully OP hasn't been sitting on those parts the last 18 days waiting for programming advice.
  9. Likes Mtndew liked this post
  10. #6
    Jun 2012
    Michigan
    3,527
    2910
    2041
    Quote Originally Posted by dodgin View Post
    Yep, rough with 2D Dynamic, and finish with 2D Contour.
  11. Likes mhajicek, dodgin, Volitan liked this post
  12. #7
    May 2017
    Minnesota
    214
    143
    108
    Quote Originally Posted by Mtndew View Post
    ^^^^^^^^^^^^ Correct answer.
  13. Likes Mtndew, [email protected] liked this post
  14. #8
    Jan 2012
    Savannah, Georgia, USA
    1,614
    2587
    576
    Quote Originally Posted by mhajicek View Post
    That's my bread and butter everyday.
