Mastercam post issue
Results 1 to 7 of 7
    Sep 2017
    New York
    14
    Default Mastercam post issue
    So I just bought a used mill and they gave me the post for it also problem is I have mastercam x5 they had x8 is there any way to make it into an x5 post. I tried a bunch of different things but can’t figure out how to convert it from x8 to x5. I know now they have migration wizards and that makes them to the newest version but I’m kind of stuck and not really sure what to do now. Or do I just have upgrade to x8 or newer so I can update it that way.
  2. Likes TopSolidCAM... liked this post
  3. #2
    Mar 2015
    Michigan
    260
    39
    72
    If the post you have isn't working and you need a different post you should contact your reseller.
    Nov 2007
    canada
    456
    62
    191
    Never tried going backwards but you could try editing the first line in the post.
    Change..
    V17.00 W17.00 M17.00
    to...
    V14.00 W14.00 M14.00
    I think those are the numbers for X8 and X5 respectively.
    I have no idea if that will work so make sure whatever is in that line now is saved in case you delete something by accident.
    Jun 2012
    Michigan
    3,682
    3148
    2125
    What control is the post for?
    Sep 2017
    New York
    14
    PC-2100 control
    Jun 2006
    Huntsville Alabama
    1,782
    1024
    678
    Contact your reseller, or start modifying a MpMaster free post
    Dec 2014
    98
    11
    11
    I used to do this for customers from time to time. It will probably work with minimal errors. You take an x5 control and machine def and then assign it to the post. You might have some post errors that need fixing. Your re seller should be able to knock it out over an online meeting in 10 min.
    1 - copy machine and control definition from a the generic 4x mill rename to your machine
    2 - open the Machine def you just created and then re-assign the control def. Save
    3 - re-assign the post in the control def. There is small dance to this...
    4 - Try to post something. If you get errors, go in there and fix them.
    It's not a huge deal, don't let anyone tell you its not possible.
