also you might have this value.
ret_on_indx : 1 #Machine home retract on rotary index moves, (0 = no, 1 = yes)
turn it on off depending if you want the machine to go to its home position in the Z before indexing.
OK so you will be looking for this string selection table. ONLY CHANGE what is between quotes.
# Table rotation direction
# Table rotation direction, index
sindx_cw : "M60" #Rotate CW code
sindx_ccw : "M61" #Rotate CCW code
sindx_mc : "" #Target for string
fstrsel sindx_cw indx_mc sindx_mc 2 -1
Ok, one more thing. If the control def does not work and it will not index, check for this variable in your post:
use_rotmcode : 1 #Output M-Code for Axis direction (sindx_mc)
#0 = Signed direction (only valid when rot_type = 1)
#1 = M-Code for direction
set it to 1
Hope that helps.
