AD Design
Stainless
- Jun 27, 2012
- Tennessee USA
Could really use some advice from the collective. I am soon to inherit a great lot of CAD files (1,000's) created with the ME-10 program. To make a long story shorter the program is currently not functional. The information on those files is still needed on an almost daily basis for viewing and to create stamping die components on the WEDM. Viewing is not the problem, I can get Creo Elements to open the files but not save to a useful format. We've already been in touch with PTC and they haven't offered much help other than suggest a configuration edit in Creo that doesn't work. I've already found/used the translator that comes with Creo but am not successful in converting the older files, I get a screen message that states the file is not ASCII type. The translator does work for files I create in Creo/save to dxf/convert to .mi and back so it does work for some files. All of the reading/searching I've done suggests that there are "unique" aspects about converting .mi files and some data may be lost. It also appears that the time to have migrated away from ME-10 was at least 10 years ago when translators/converters were needed and more readily available. One of the IT guys at corporate has suggested/stated that the older files that we can't convert were/are written in a binary code. This is now squarely beyond the limit my knowledge. I'm attempting to pursue a solution because a problem that doesn't directly affect corporate seems to have less of a priority, it's been 4 weeks already. I have an outside company reviewing the problems but I'm willing to bet that the cost will cause much wailing and gnashing of teeth in the corridors of power. So before I just step back and let the ball fall I wanted to ask if any of you have had to wrestle with the legacy of a large data base in an unsupported program and whether you found a solution. A batch translator would be great but if a single serving conversion is all that's possible then the company needs to hear this too. Thanking you in advance for your time and advice. I hate it when short sighted bean counters make decisions that bite someone else in the arse. My apologies for the rant.
